After removing the stock instruments I cut the back of the instrument panel off with a dremel. Then I installed Autometer gauges: 2 1/16" Pryometer and Voltmeter and a 2 5/8 Boost gauge. I did need to sandpaper the middle hole a little as the boost gauge was a bit bigger. After about an hour of cutting and sanding I had all 3 installed. Another 20 minutes and the lights were soldered with quick connects. The signal wires and boost line will get installed a bit later.
