Hello Folks,
Can you help me get perspective on a mechanic's bill? I'll say what was done and you tell how many hours you figure it could/should be.
1) Replace ring gear/flex plate. While in there replace crankshaft rear main seal, replace starter drive, replace transmission input seal.
2) Replace rear differential pinion seal.
3) Replace both sides outer tie rod end boots.
Thanks for playing!
getting perspective on a mechanic bill
Ender-Beeshi
- Vehicle: 95 Delica Exceed
legionnair
- Vehicle: delica L300
Re: getting perspective on a mechanic bill
First one 7 hours
Second one 1
Last one 1
But that's if they come apart and go together well, you could add more time easy.
Also my shop rate is $45/hr
So that gives me more wiggle room
Dustin
Second one 1
Last one 1
Dustin
Ender-Beeshi
Hi Dustin,
Thanks for playing. Wish you worked in the interior!
