Fwd control Jeep
Fwd control Jeep
wow
I've always loved Jeep's. Owned a CJ5, CJ7 and a handful of XJ's.
This is one gorgeous conversion.
The F-C is another important project for the Jeep design team as it continues to push and reinforce the brand emphasis on utility and brand heritage. While other US brands have bloated and softened their product lines at nearly the same rate as American waistlines, Jeep has actually become more capable and more purposeful
http://expeditionportal.com/vehicules/4 ... drive.html
nxski
Re: Fwd control Jeep
Post by nxski »
I saw that on expedition portal a couple weeks ago. I thought it was a concept vehicle bases on an older model though!?
Luna-Sea
Post by Luna-Sea »
Drool,
The article does not mention the powerplant.
The were using some italian VM motori and fiat diesels also a Mercedes
lately, throw an OM617 Benz straight 5 cylinder in there
And make it a crew cab!
Right On! 8-)
thedjjack
Vehicle: 1989 L300 HITOP!!
Post by thedjjack »
When I saw it ...I thought maybe I should get a 4 door tube and start cutting...I was think removable top would be handy too..
On a 2 or 3 ton chassis with a nice inline 6 cylinder diesel 8.3 cummins...
Luna-Sea wrote:The article does not mention the powerplant.
The original JK CRD diesel would be nice but it's not offered here in Canada/US. Just like most small diesels. :-(
Jeep JK CRD 3.0 specs (not sold in Canada/US)
Fuel System..............Common rail diesel, compression direct injection
Maximum torque.......376 lb ft @ 1600 rpm
Maximum power........215 bhp @ 4000 rpm
CO2 Emissions...........284 g/km
Combined Cycle.........26.2 (10.8) mpg (l/100 km)
Extra Urban Cycle......30.7 (9.2) mpg (l/100 km)
Urban Cycle...............20.9 (13.5) mpg (l/100 km)
nxski wrote:I saw that on expedition portal a couple weeks ago. I thought it was a concept vehicle bases on an older model though!?
Here's the original article
To create the concept, the design team started with a new 2012 Jeep Wrangler Rubicon, moved the cab ahead of the front axle, lengthened the wheelbase, and installed a custom 8 foot drop-side pick-up bed. The cab uses several parts from the JK-8 kit, and the chassis features components from well known companies such as King Shocks, Teraflex, Hanson Bumpers, and Hutchinson beadlocks.
http://expeditionportal.com/vehicules/4 ... ntrol.html
Strada 92
Vehicle: Mitsubishi Delica L400 1995
Post by Strada 92 »
Wow,really cool.
Looks like a Volkswagen transporter single cab
Mitsubishi L400 Spacegear
Mitsubishi I-MiEV 2012
thedjjack
Post by thedjjack »
Here is the one I built...1967 OM617 Mercedes 4speed auto, divorced 205, dana44/60
Next time I will build a JK-fc I think :-D :-D :-D
Jeep FC150 history:
http://www.jpmagazine.com/featuredvehic ... index.html
"Maximum payload on minimum wheelbase" is how Jeep pushed the Forward Control. That, and its visibility, maneuverability, and stationary power from three separate take-off points. The motto back in the late 1950s was, "A Jeep for every job," and this was the work truck in the CJ lineup. The vehicle's appearance and cab-over-engine style were deemed forward-thinking at the time. After all, you could "see the road six feet from the front bumper." Ah, yes, "forward-thinking"- the design equivalent of "butter face."
The History
The Forward Control (better known as the FC series) debuted in 1956 (for Willys Motors) and was euthanized in 1965 (by Kaiser Jeep). Its quirk was that the cab was forward of the engine (creating extra cargo space), right smack over the front wheels. That made it an equal competitor for cargo-carrying abilities (other than spare tire/wheelwell issues), but it was nimble too (a turning radius of 18 feet). As you might suspect from looking at it, the FC was a wee light in the front-end loafers-therefore, on the 150 model, its real quirk had to do with a problem of tipping on its nose when heading down hill (a cast-iron weight was later added behind the rear axle).
The Model/The Body
The FC-150 was the first in the series to arrive, a no-brainer launch because it used the CJ-5 chassis. A year later came the FC-170, built off a widened Willys utility-wagon chassis. It was wider (76.94 inches), longer (181.47 inches), and taller (79.41 inches) than the 150, and its turning radius measured in at 21 feet. What made the cab-over unique was the payload-to-weight ratio-on the 170, it maxxed out at 3,510 pounds in a 45-cubic-foot box on that 103.5-inch wheelbase. The 81-inch FC wheelbase could carry 1,635 pounds in the stake body, 1,727 as a pickup. The '59 FC-170 added a heavy-duty model, with a beefier rearend and dualie rear tires. That same year, the FCs saw a slight redesign of the cab (a more level tunnel, for example) for better cooling.
The Engine
The FC-150 sported the CJ-familiar four-cylinder F-head Hurricane engine, which made 72 hp and 114 lb-ft of torque. The 170 had the 226-ci High Torque Super Hurricane six-cylinder for 190 lb-ft of torque at 1,400 rpm and 105 hp at 3,600 rpm. It had a compression ratio of 6.86:1 (although 7.3:1 was the optional ratio) and a bore-and-stroke of 3.312x4.375 inches. And, yes, the engine was pretty much accessible from inside the cab. A Cerlist three-cylinder diesel was also available, but only on some military models. It pumped out 85 hp and 170 lb-ft.
The Transmission
The standard transmission was the floor-shift, synchromesh three-speed Borg-Warner T-90A, although the heavier-duty synchromesh Borg-Warner T-98 four-speed was also available a few years later.
The Transfer Case
Both the FC-150 and FC-170 came equipped with the two-speed Spicer Model 18 T-case with 2.43:1 low ratio.
The Suspension/Axles
The FC-150 started off with a Dana 25 frontend, but in about two years made the leap to a closed-knuckle Dana 44 (this helped with stability). A Dana 44 brought up the rear on the 150. Meanwhile, the FC-170 ran with a 44 up front and a 53 rear (out back was a semi-floater that had a capacity of 4,500 pounds). The 170 had 4.88 gears; the 150 used 5.38s. In addition to the axle upgrade to try to keep the 150 upright, a year later there was a switch to a wider track (57 inches front and rear; the 170 was at 63 inches), and the leaf springs were moved outside the frame (matching the 170).
Also in 1959 came components that could bump the 170 from its 7,000 GVW class to 8,000- and 9,000-pound grouping. Opting for the modified platform stake model's heavy-duty rear springs equaled nine leaves rated at 672 pounds per inch and a capacity of 7,500 pounds, plus a Dana 70 dualie rearend or stronger Dana 53. Bigger rear shocks and 12- and 13-inch drum brakes (front and rear, respectively) could also be had.
tonydca
Post by tonydca »
Very cool!
Although I don't think those portal axles are standard Jeep Rubicon fare, at least not at $23,500 for the pair (*gulp!*):
http://blog.caranddriver.com/new-mopar- ... tal-axles/
Return to “On the Web”
