Black smoke
- lettereleven
- Vehicle: L400 Super Exceed
Black smoke
Just made it up to Whistler - as I drive I noticed a unnatural amount of black smoke while going up hill. It usually went away at higher rpm. I haven't noticed it at all while driving in the city.
I am not sure what I need to investigate to sort it out. If someone can point me in the right (or possible) direction that would be awesome.
Possiblly?
Glow plugs
Injectors
Time for a seafoam rinse
Not sure if it matters, but it's been a bit rougher on morning starts lately.
Thanks ever so much
Jamie
Possiblly?
Glow plugs
Injectors
Thanks ever so much
Jamie
Re: Black smoke
seafoam it first
also check that catch can you have in there. If I recall, the hose is busted?
Next injectors cleaned/calibrated
Next IP timing
Next IP timing
- lettereleven
Black smoke
Thanks for the strategy. I've already bookmarked the post on the sea foam and had planned on doing it next oil change. I'll just bump it up to next weekend.
- tonydca
Re: Black smoke
As a Seafoam alternative - which I *do* think is great stuff BTW - if you really want to give your injectors a flush, buy some pure isopropyl (rubbing) alcohol (not the London Drugs variety), run your fuel tank down low and take 'er for a good highway run after adding it:
http://www.delica.ca/forum/big-ol-post- ... 12355.html
- lettereleven
Black smoke
Thanks guys. I will try the IPA first as its free. Then seafoam and new oil, fuel and air filters -just changed oil filers 2 weeks ago so I feel badly dumping it all out.
If none of that works I will have to take it in.
Thanks for the ongoing help.
J
J
- lettereleven
Black smoke
Thanks again for the help. Last week I did a run with IPA and it really helped! No nasty black smoke anymore.
I also thought that checking the air filter might be worthwhile (suggested in other threads). Just changed it this morning. Yikes - pretty nasty.
- lettereleven
Black smoke
And here comes the moment of truth.... Aircare.
- lettereleven
Re: Black smoke
Passed!
Except perhaps less-than-great mileage as judged by AirCare (17L/100km)
mrraulduke
- Vehicle: 96 L400 SWB
Re: Black smoke
what is a natural amount of black smoke?
This is my first diesel, and i get it taking off from a light, or when i gun it to merge, i see a plume of black.
Also i have a bit of white smoke at start up, but a puff and it's gone and idles normally.
Re: Black smoke
The puff at start is normal. A diesel drives differently from a gas vehicle. You can't just slam your foot down to accelerate. Try accellerating slower and see if that black cloud goes away. Also, I'd recommend blanking your egr if you haven't already, and changing your air filter.mrraulduke wrote:what is a natural amount of black smoke?
- Mr. Flibble
Re: Black smoke
Diesel smoke colours and causes: http://www.dieselbombers.com/general-di ... -what.html
Black, in your case is either too much fuel or not enough air.
