L300 Front Diff Locker - SOLVED!!!!
Posted: Thu Feb 23, 2012 1:39 pm
Hi guys,
I have recieved alot of info from this site over the years and thought I would re-post this here for those without an account on the Aus Delica forum. Some of you may remember the post from a while back but I think it was deleted with my old account... I now have added the final write up with some more pics....
Problems;
1 - L300 has a 7.25" front diff so there are no lockers available (or ever will be due to low demand and twin spider gears making the crown wheel housing cramped and small)
2 - L300 has a Low Pinion front diff (driveshaft connects on the lower half of the diff) so you cannot use a L400/Pajero KN5 diff as it is High Pinion. (it will foul on the engine and the pinion shaft angle is not nice at the transfer case and front diff flange)
3 - The L400/Pajero KN5 diff also has super select which I don't want as that's another thing to break....L300's don't have a centre diff so this is pretty useless anyway.
4 - Gen1 8" LP front diffs only come in 4.625 ratios (I have looked for over 2 years now and visited countless wreckers), while the L300 is 4.875. You can swap into the rear L300 diff a rear Pajero 2.5td 4.625 ratio 8" rear centre. Some early petrol L300'salso had a 4.625 LSD rear diff also.
5 - The triton/l200 has wrong axle over leaf setup and pajero track is too wide so you can't do an entire axle swap either.
Solution;
After many false hopes of finding a 8" non-Super Select Low Pinion 4.875 ratio front diff out of a Pajero (apparently they did make them....), I gave up putting my front locker in the van....
On the weekend I replaced the open rear diff on my van with a LSD item from a chamoix l300. It was a direct swap (only need the centre as the axles are exactly the same)!!!
The crown wheel & pinion shaft on the rear 8" diff is identical to the crown wheel & pinion shaft (thank mitsubuishi for sharing parts here otherwise this would have been the end of the project) on the 8" front diff from a gen1 pajero.
Delica/L300 8" Rear Open Diff - Crown Wheel: 39 teeth, Pinion Gear: 8 teeth (4.875 ratio)
Pajero/Triton 8" Front Diff - Crown Wheel: 37 teeth, Pinion Gear: 8 teeth (4.625 ratio)
Basically if you want a front locker for your L300 you will need;
1 - L300 Rear 8" Diff Crown Wheel & Pinion Shaft/gear (as a pair)
2 - Pajero/Triton Gen1 V6 3.0l Manual Transmission 8" Front diff (make sure it's 8" and Low Pinion, Gen2 Pajeros have High Pinion and all other Pajero's in Gen1 other than the V6 manual transmission got 7.25" front diffs).
3 - Diff shop to fit in L300 rear diff crown wheel and pinion shaft to Pajero front diff and crown wheel carrier.
4 - ARB Locker/Lockright/Lokka or any front locker for a Gen1 Pajero 8" front diff.
5 - Make bracket for the side mount on the Pajero front diff, as the L300 front diff doesn't have the side mount. (Not really necessary)
6 - Custom front prop shaft to account for the 8" front diff
7 - Use the L300 RHS Halfshaft as it has the mounting to the front cross-member already. And you can retain both LHS and RHS L300 CV/Drive shafts (only if you originally had an L300 with 28spline shafts not the 25spline version)
8 - Have lots off fun off road!!!!
Pic of a 8" Pajero (LHS) and 7.25" Pajero (RHS) front diffs...note the side mounting tab, l300's don't have this.
How to Identify Pajero Diffs;
* 7.25" Low Pinion - KN? (25 spline). straight ridge from the drain plug all the way back to the pinion flange area (Pajero/Triton)
* 7.25" Low Pinion - KN2 (28 spline). straight ridge from the drain plug all the way back to the pinion flange area (Pajero/Triton)
* 7.25" Low Pinion - KN3 (28 spline). no ridge at the drain plug but a ridge rotated to the side at the pinion flange area (L300/Delica)
* 8" Low Pinion - KN33 (28 spline). ridge from the drain plug and then rotated to the side at the pinion flange area (Pajero/Triton)
Problems;
Solution;
