A few fuel related observations
Posted: Mon Nov 07, 2011 10:04 am
Given my latest bout of excitement with the Delica (regular unleaded vs. diesel in the tank) I was able to make a few observations that I thought I'd share with the rest of the Delica community (however unimportant these observations may be
- The fuel tank capacity for an auto-tranny L300 is quoted at around 65 Liters
- In reality, a completely drained out system (fuel line empty, tanks purged, fuel filter empty) holds almost 82 Liters.
I drained all the mixed Diesel/Gas fuel out of the system due to the accidental fill-up with gasoline, disconnected and emptied the fuel lines, installed a new fuel filter and then put 40 Liters of Diesel in and primed the system up to then start the vehicle.
Then I drove 4.5 Kilometers to the next Petro-Canada where I filled another 42 Liters of Diesel. This amounts to 82 Liters (minus 4.5 Kilometers driven) of diesel that our automatic L300's can hold. Not that I will keep driving with the yellow "empty" light on, but clearly, after burning through 65 Liters of Diesel, there is still approximately 15-17 Liters in the tank.
I figured if the fuel line holds 1 Liter and the Fuel filter holds maybe half that, the tanks are indeed a bit larger than quoted in the manual...
Another thing that I noted with satisfaction is the fact that our vehicles are particularly friendly to work on when it comes to fiddling with the fuel system. I am not aware of too many other vehicles that conveniently have drain-plugs on their tanks. I was talking to my brother in law who had to drop the tank right out of a Dodge Cummins Diesel Truck to empty an accidental gas-fill-up on their way back from a hunting trip from Chetwynd... (this was done in the middle of the night, on the side of the road with flash light illumination...) - I bet they would have been a bit happier if they had had the opportunity to simply open up a drain plug on the bottom of the tank...
The other thing that is a very pleasant convenience is the fact that one can prime/pump fuel up from the tank to the filter, by simply pumping by hand on the fuel filter housing... imagine if the engine had to suck up all the diesel by use of the regular (mechanical) fuel pump... so much easier and quicker to get the show back on the road...
These are just little things - but if you do have a problem with an accidental gas-instead-of-diesel-fill-up, you certainly come to appreciate these nice features...
Nevertheless hope that nobody will have to deal with fuel mix-ups... I (and my wife) file this under the "lessons learned" category...
Chris
Chris
