				Starter/Alternator died??
				Posted: Tue Sep 27, 2011 5:37 am
				by L300Foca
				When i turn key to start engine i jus hear thinythiny click :)
Whats happend? :)
				Re: Starter/Alternator died??
				Posted: Tue Sep 27, 2011 1:21 pm
				by ubernub
				Check the battery voltage, if its low, the starter wont be able to kick in!
				Posted: Wed Sep 28, 2011 7:45 am
				by L300Foca
				ubernub wrote:Check the battery voltage, if its low, the starter wont be able to kick in!
Battery is new :)
				Posted: Wed Sep 28, 2011 7:57 am
				by yojimbo
				Then it may not be charging, whats the voltage across it while the engine is running, and while it's not?
				Posted: Wed Sep 28, 2011 9:52 am
				by shealy
				Are you getting any power at all from the battery (do the interior lights still come on and glow plugs work etc.)?  If so I had this issue happen the other week. Try turning the key to where you can shift, hold your food on the break and shift through all the gears (p to n, back to park. P to r back to park etc.). Then try starting again. Worked for me. Good luck!
				Re:
				Posted: Wed Sep 28, 2011 1:04 pm
				by L300Foca
				shealy wrote:Are you getting any power at all from the battery (do the interior lights still come on and glow plugs work etc.)?  If so I had this issue happen the other week. Try turning the key to where you can shift, hold your food on the break and shift through all the gears (p to n, back to park. P to r back to park etc.). Then try starting again. Worked for me. Good luck!
I will try that :)
As well, my alternator is ok, STARTER is like click click :)
