1996 L400 Jasper High Roof in Transit $11,400_NO HST
Rising Sun Auto Import
NO HST SALE!
**June/1996, Jasper high roof, ladder, 2800cc turbo diesel, automatic, 125K, original rims, ps, pw, airbag, winter package, green 2 tone color, auction grade 4.
Price ; $11,400
Will be in Canada at July15.
We are accepting hold deposit. Ask for details.
Here are lists we check/replace for our stock delicas.
1. Engine componenets
** IP front seal replacement, valve adjustment, timing chain tension/loose adjustment, make sure no oil leaks
2. Transmission/4WD fuction
** If anything wrong, we replace sensor/switch, etc
3. steering/suspension/axle
** repack hub, and replace bearing if worn, all bushings/ball joints/CV boots/rack & pinion boot /links replaced if needed, wheel alignment, etc.
4. brake system
** flushing fluids, rotor machined or replaced, replace brake pads under 60% depth, all caliper checked
5. cooling system
** new radiator, new water pump, new thermostat, new hoses, new expansion bottle if needed.
** new temp guage/switch if needed
6. starting
** new battery if needed, new Hyundai 11V glow plugs ( best in Canada ), check glow plug relay/wiring, alternator/starter checked, make sure initial idle good.
7. interior
** make sure no broken parts, all power groups are working
8. exterior
** We focus on importing clean/good shape cars, no worry.
9. all fluids replaced ( engine oil, coolant, transmission oil, transfer case oil, front/rear differential oil ), new air filter/new fuel filter,all new V-belt, a/c checked and refilled.
10. compliance
** new tires Yokohama Geolandar A/T-S ( upgrade available with extra cost ), new e-coded headlight, DRL, marker/reflectors
11. canadian version CD player/stereo
** it is not included in our listing price.
12. block heater, trailer hitch
** installation extra
We have 7 Delicas this month.
For more in transit delica info, visit our website.
http://www.rs-import.ca/shop/step_subma ... 0723014349
Steven 778-995-2459
David 778-237-4602
or shop 604-544-5120
