1995 L400 Exceed Black, Roof Rack_compliance/servicing
Posted: Sat Jul 09, 2011 6:11 am
				High Roof, Grade 3.5, black over grey.
7 Seaters (Middle Row Captain Seats), Aluminum Roof Rack, Ladder, Bush Guard, Aftermarket Alloy Rims, Skid Plate, Air Conditioning, Power Steering, Tinted Windows, and More.
This clean black L400 is in transit and will be landed on July15.
Price ; $11,900
Here are lists we check/replace for our stock delicas.
1. Engine componenets
** IP front seal replacement, valve adjustment, timing chain tension/loose adjustment, make sure no oil leaks( in case of L300, new timing belt/balancer belt/tensioners, 4 front oil seals replaced )
2. Transmission/4WD fuction
** If anything wrong, we replace sensor/switch, etc
3. steering/suspension/axle
** repack hub, and replace bearing if worn, all bushings/ball joints/CV boots/rack & pinion boot /links replaced if needed, wheel alignment, etc.
4. brake system
** flushing fluids, rotor machined or replaced, replace brake pads under 60% depth, all caliper checked
5. cooling system
** new radiator, new water pump, new thermostat, new hoses, new expansion bottle if needed.
** new temp guage/switch if needed
6. starting
** new battery if needed, new Hyundai glow plugs ( best in Canada ), check glow plug relay/wiring, alternator/starter checked, make sure initial idle good.
7. interior
** make sure no broken parts, all power groups are working
8. exterior
** We focus on importing clean/good shape cars, no worry.
9. all fluids replaced ( engine oil, coolant, transmission oil, transfer case oil, front/rear differential oil ), new air filter/new fuel filter,all new V-belt, a/c checked and refilled.
10. compliance
** new tires Yokohama Geolandar A/T-S ( upgrade available with extra cost ), new e-coded headlight, DRL, marker/reflectors
11. canadian version CD player/stereo
** it is not included in our listing price.
12. block heater, trailer hitch
** installation extra
We might have missed some lists, but we are very proud of our job.
We are accepting hold deposit.
We have 7 Delicas this month.
For more in transit delica info, visit our website.
http://www.rs-import.ca/shop/step_subma ... 0723014349
Steven & David
** good/clean Delicas with affordable price/perfect maintenance into Canada**
Price ; $11,900
4. brake system
5. cooling system
6. starting
7. interior
8. exterior
10. compliance
Steven & David
