95 Mitsubishi Delica Spacegear LWB
Posted: Sun Jun 26, 2011 2:27 am
				RARE FIND 1995 MITSUBISHI DELICA LONG WHEEL BASE DIESEL SPACEGEAR. RECENTLY IMPORTED AND MAINTENANCE COMPLETED.  THE FOLLOWING SERVICING HAS BEEN DONE: NEW CONTROL ARM BUSHING, LOWER BALL JOINT REPLACE, WHEEL ALIGNMENT COMPLETE, FRONT ROTORS REPLACE WITH NEW BRAKE PADS, REAR BRAKE PADS, FRONT HUB BEARING REPACKED, FRESH COOLANT, NEW ENGINE OIL WITH FILTER, TRANSMISSION FLUID, DIFFERENTIAL FLUIDS. NO RUST UNDERNEAT, ROOF OR BODY, CLEAN DELICA.
NO NEED TO DO ANY OTHER MAINTENANCE WORK, JUST DRIVE AWAY.
BC INSPECTION COMPLETED WITH 4 BRAND NEW YOKOHAMA GEOLANDERS TIRES. NO CUTTING CORNERS, ALL QUALITY WORK WITH QUALITY PARTS!
