96 Mitsubishi L400 LWB T-Diesel Auto 156,k in Transit
- MardyDelica
1996 L400 Delica Spacegear 2.8L intercooler turbo Diesel, 4m40 engine, Auto, 4x4, Super Exceed model, Winter package With Dual battery Blue color, L400, has 156,000 kms.
This L400 White Lwb is hard to find now a days
Its a grade 3.5 which is good
no rust under been inspected on site
This one has Airbag and staineless exhaust.upgraded suspension.
no rust,
with wheel flair which is nice and nice front bull bar
with nice stainless rear ladder
Has a newer trottle control when starting in cold start like the chamonix
Things will do to this lovely nice White Super exceed L400 LWB:
install brand new 4 tire Yokohama all terrain tread pattern mud & snow
install new block heater
4 new pro comp 9000 series shock heavy duty one
brand new front & rear brake pads ( made in Japan pads)
machine front & rear rotors,
re-pack front hub both side
new front stabilzer link
new e-code headlight with led DRL headlight
No rust
New transmission Filter & fluids
new oil change & all fluids has been change front to rear
new front & rear reflector
brand new L400 antifreeze water bottle
new water pump
new thermosthat
All new fan belt 3 pcs
replace new front injection pump seal
Clean & pre set the 4 injector
New valve cover gasket
Do adjust TPS sensor timing to have a proper & smooth shifting of your L400 will runs like a car
will also install a newly conversion glow plug bas bar & cable to ensure to have a proper volts to each glow plug.
the old one or original one sometime dont give correct full voltage need the glow plug to heat it up when need to start this L400 when the weather is cold.
now it been tested to my other L400 & it works really good mostly when it in a cold early morning.
we try to improved the glow plug issue for this L400 when its reach a very cold weather & we prove it now that it works very good. its a big help when we install this.
so buyer beware. thru us we only sell mostly fully service vehicle to give full customer satisfaction &
its a must to see before buying this type of delica for you & your family
we offer the best possible price for your budget with full service on this Delica
For your inquiry pls feel free to contact me, will more than happy to answer all your question.
This L400 comes with 1 year or 12,000 kms power train warantty whichever comes first
Price: Pls call for inquiry,
Stock # PF8W=156K White
Amazing Auto Imports LTD
Any questions please call me:
604-247-2111 / 604-720-6144
thanks,
no rust,
No rust
new water pump
new thermosthat
thanks,
- DSCN3549.JPG (84.44 KiB) Viewed 20712 times
- DSCN3550.JPG (81.82 KiB) Viewed 20712 times
- DSCN3552.JPG (83.69 KiB) Viewed 20712 times
- DSCN3555.JPG (84.38 KiB) Viewed 20712 times
- DSCN3556.JPG (87.4 KiB) Viewed 20712 times
- DSCN3560.JPG (79.43 KiB) Viewed 20712 times
- MardyDelica
Re: 96 Mitsubishi L400 LWB T-Diesel Auto 156,k $12,600 in ja
More pictures;
- DSCN3566.JPG (68.12 KiB) Viewed 20711 times
- DSCN3561.JPG (83.28 KiB) Viewed 20711 times
- DSCN3563.JPG (63.55 KiB) Viewed 20711 times
- DSCN3564.JPG (75.85 KiB) Viewed 20711 times
- DSCN3571.JPG (82.09 KiB) Viewed 20711 times
- DSCN3578.JPG (75.6 KiB) Viewed 20711 times
- MardyDelica
more pictures;
- DSCN3582.JPG (87.25 KiB) Viewed 20709 times
- DSCN3591.JPG (78.86 KiB) Viewed 20709 times
- DSCN3588.JPG (93.25 KiB) Viewed 20709 times
- DSCN3589.JPG (93.25 KiB) Viewed 20709 times
- DSCN3580.JPG (92.11 KiB) Viewed 20709 times
psilosin
- Vehicle: L400
Looks nice!
I'd suggest your man in Japan remove the Grateful Dead sticker befor shipping...I could see that being a reason for canada customs to bring out the drug sniffing dogs lol
- MardyDelica
Hi, which sticker is this pls tell me dont get it
pls let me know
Cheers;
mardy
pls let me know
Cheers;
mardy
Mr. Pistachio
- Vehicle: L400 LWB Super Exceed
On the back window.
Here's a picture of it!
Antoine
Antoine
- sky571_sticker_grateful_dead-.gif (16.27 KiB) Viewed 20625 times
One should never remove a Deadhead sticker from a vehicle, that is sacrilege. A vehicle touched by the Grateful Dead is a vehicle that is truly blessed.
- CREGAN
and usually smells a bit skunky.FalcoColumbarius wrote:. A vehicle touched by the Grateful Dead is a vehicle that is truly blessed.
- MardyDelica
bassnailer
I couldn't agree more!CREGAN wrote:and usually smells a bit skunky.FalcoColumbarius wrote:. A vehicle touched by the Grateful Dead is a vehicle that is truly blessed.
Nice L400 Mardy !
You don't see many Super Exceed White LWB's !!!!!!!!
- MardyDelica
yes, thanks jessie,
hard to find also thsi one has a throttle knob attached on it like chamonix
not bad with all the accesories on it.
cheers;
cheers;
- solanoid
yummmCREGAN wrote:and usually smells a bit skunky.FalcoColumbarius wrote:. A vehicle touched by the Grateful Dead is a vehicle that is truly blessed.
HeathenForce-http://www.ultragod.com/
- sasquatch-hunter
- Vehicle: 2 Delica
This GD van is truely a "Space" gear.
Yeah... like, wow....... (~};)
