1995 L400 Delica Spacegear 2.8L intercooler turbo Diesel, 4m40 engine, Auto, 4x4, Super Exceed model, Winter package With Dual battery Blue color, L400, has 141,000 kms.
This L400 Blue lwb is ahrd to find now a days
Its a grade 4 which is good
no rust under been inspected on site
Things will do to this lovely nice Blue Super exceed L400 LWB:
install brand new 4 tire Yokohama all terrain tread pattern mud & snow
install new block heater
4 new pro comp 9000 series shock heavy duty one
brand new front & rear brake pads ( made in Japan pads)
machine front & rear rotors,
re-pack front hub both side
new front stabilzer link
new e-code headlight with led DRL headlight
No rust
New transmission Filter & fluids
new oil change & all fluids has been change front to rear
new front & rear reflector
brand new L400 antifreeze water bottle
new water pump
new thermosthat
All new fan belt 3 pcs
replace new front injection pump seal
Clean & pre set the 4 injector
New valve cover gasket
Do adjust TPS sensor timing to have a proper & smooth shifting of your L400 will runs like a car
will also install a newly conversion glow plug bas bar & cable to ensure to have a proper volts to each glow plug.
the old one or original one sometime dont give correct full voltage need the glow plug to heat it up when need to start this L400 when the weather is cold.
now it been tested to my other L400 & it works really good mostly when it in a cold early morning.
we try to improved the glow plug issue for this L400 when its reach a very cold weather & we prove it now that it works very good. its a big help when we install this.
so buyer beware. thru us we only sell mostly fully service vehicle to give full customer satisfaction &
its a must to see before buying this type of delica for you & your family
we offer the best possible price for your budget with full service on this Delica
For your inquiry pls feel free to contact me, will more than happy to answer all your question.
This L400 comes with 1 year or 12,000 kms power train warantty whichever comes first
SOLD
Stock # PF8W=141K Blue
Amazing Auto Imports LTD
Any questions please call me:
604-247-2111 / 604-720-6144
thanks,
95 Mitsubishi Delica Lwb T-Diesel Auto 141k SOLD
- MardyDelica
- DSCN3283.JPG (87.75 KiB) Viewed 18088 times
- DSCN3286.JPG (85.6 KiB) Viewed 18088 times
- DSCN3294.JPG (84.25 KiB) Viewed 18088 times
- DSCN3288.JPG (81.26 KiB) Viewed 18088 times
- DSCN3290.JPG (80.86 KiB) Viewed 18088 times
- MardyDelica
Re: 95 Mitsubishi Delica Lwb T-Diesel Auto 141k $ 11,800
more pictures;
- DSCN3291.JPG (76.91 KiB) Viewed 18084 times
- DSCN3318.JPG (82.82 KiB) Viewed 18084 times
- DSCN3316.JPG (76.98 KiB) Viewed 18084 times
- DSCN3314.JPG (73.38 KiB) Viewed 18084 times
- DSCN3319.JPG (42.67 KiB) Viewed 18084 times
- DSCN3323.JPG (89.47 KiB) Viewed 18088 times
- MardyDelica
Still for sale nice long wheel base no rust
this comes with full service not partial or just do change oil when they say full service
cheers;
cheers;
- MardyDelica
Re: 95 Mitsubishi Delica Lwb T-Diesel Auto 141k in Transit
this nice super exceed L400 LWB is in transit
hard to find a nice LWB L400 this is one of the nice one
will be here next month;
Cheers;
Cheers;
- MardyDelica
Re: 95 Mitsubishi Delica Lwb T-Diesel Auto 141k on Hold
This Nice L400 is on Hold:
thank you very nice,
hard to find nice one like this wihtout any rust:
Cheers;
Cheers;
- MardyDelica
Re: 95 Mitsubishi Delica Lwb T-Diesel Auto 141k in transit
this L400 is in transit
Cheers;
Cheers;
- MardyDelica
Re: 95 Mitsubishi Delica Lwb T-Diesel Auto 141k Arrived
This Nice L400 Arrived In Canada.
runs very good and doing a service now;
Cheers:
Cheers:
- MardyDelica
Re: 95 Mitsubishi Delica Lwb T-Diesel Auto 141k SOLD
This L400 is SOLD
thank you very much,
Cheers;
Cheers;
