Can a Delica handle rough logging roads in coastal BC?
jaeger
- Vehicle: none yet
Hi,
I've had my heart set on buying a Delica for quite a while. I'm wondering if a Delica, or a particular model could handle rough logging roads on Haida Gwaii. Not much snow, but it would have to have the clearance and enough muscle to get/keep me out of the mud and huge puddles. Any advice would be most welcome.
Re: Can a Delica handle rough logging roads in coastal BC?
Depends on your definition of huge puddles
The L300 is very capable offroad.
If you want clearance, a unimog is a good option
- Super Exceeded
- Vehicle: 1993 L300S
Check this out. It should put your questions to rest.
And he does it without a snorkle!!
http://www.youtube.com/watch?v=eprmfvQfEDs
Good great departure angles for deactivated roads.
For turn key factory belt. great
Amazing departure angle
Horrible approach angle
Great maneuverability due to short wheelbase
Excellent visibility
clearance is as good as the height of the diff's
Transfercase hangs down quite low but small skid plates can correct these things
I wouldn't say a 28* approach angle is all that "horrible", especially with the help of skids when you need them... Just my two bits.
- Vehicle: -
Compare to a Prius it's pretty good, compare to an Unimog not so much.FalcoColumbarius wrote:I wouldn't say a 28* approach angle is all that "horrible", especially with the help of skids when you need them... Just my two bits.
Aha... so you admit to it!fexlboi wrote:Compare to a Prius it's pretty good.
For departure angle...
http://www.youtube.com/watch?v=UeDc6xMe9u4
For approach angle...
http://www.youtube.com/watch?v=CXvxIy4Y ... re=related
It's hard to beat 90 degrees!
CloudMountain
- Vehicle: L400
Not 90 degrees but none the less wacky. Check out the guy below who is casually setting up his BBQ.
http://www.youtube.com/watch?v=cZrhuSE_ivA&NR=1
fab 1
- Vehicle: L400 Royal Exceed
Plenty of stuff regarding what a Delica L300/L400 can do on youtube some will suprise you
my personal favourite...
http://www.youtube.com/watch?v=evKmc8ma ... r_embedded
http://www.facebook.com/home.php?sk=gro ... 2360599356
- Profister
This might put some light on the poster's question:
https://picasaweb.google.com/profister/ ... directlink
http://www.youtube.com/watch?v=w2oPxKc1vg4
http://www.youtube.com/watch?v=DuwMUGKe5qE
