Are you really done with Silk Road? You haven't been even close to being done with us for the last year. Your problems never end and the delica you bought was a junk. We will never ever ignore our customers but will never ever assist you if you threaten with negative remarks by using this might forum. Here is what was wrong with your delica:
1. Locks - you were told about it and we did fix that for you
2. Bulb- one of the bulbs at the rear tailgate was burnt and you were told about
That is all the problems you had when you were taking the delica. A week or so after you took the delica, you brought it with seizing caliper and it was replaced free of charge. You did call me about having issue with over-ride and I asked you to bring it in and we will check it for you. However, I did mention to you to make sure you are in third gear when pressing the button. I don't agree with the rest of the things you have indicated and I think it is time for you to find another web forum to post to. Plus, I asked that you support your claim of having spent $6000 on your vehicle with receipt but you didn't post those. The problems you have noted cannot add up to $6000.
And for those who here sympathies with you and cheers you on, they need to know that contrary to what they believe dealers do not really like having unsatisfied customers regardless of whether they would complain on a forum like this or call repeatedly. But, are they able to be 100% successful in fully satisfying all customers, the answer is no. Every now and then we come across someone like Profitser. Plus no dealer anywhere will guarantee that something will never go wrong with your car and I certainly have never implied that. What I do guarantee is that we will always assist you if something does go wrong and I guarantee that if we are aware of any existing issue, you will be told. It is impossible to sustain a business based on falsehood and deception. It only can go on for so much. I sincerely thank some of the users who have come to our defense and I am disappointed that some users who have never dealt with us have expressed negative opinions about us. All of our cars go through a complete service including timing belt, breaks, fluid and filters change. Repair any issues we find or foresee. Each buyer is given the option of taking any of vehicles to any mechanic they choose. We are here to stay and have established a base that is only getting wider by the day and it is all because of people like you - delica and other JDM users. We cannot afford to be not nice to you guys or be dishonest with you guys. Beside very few people can tolerate going to work every day planning deception and dishonesty.
Ironically we sold all of those delicas that I advertised here before I even became aware of this thread and most to either friends or relatives of previous buyers of ours.
uote="Profister"]It has been a year and a half since I bought my Delica from Silk Road Autos, so I can conclude my previous posts providing some details.
silkroad wrote:
As for this Profister guy, please get a life.
finding yourself a good friend in profister or whatever the hell his user name is
I only had issues with this profitser guy who continues to list bogus problem he is having with his delica and it's all our fault.
It is always a pleasure dealing with a decent and polite dealer who is going after customers in case of a negative feedback. Recently this dealer also made a few false statements regarding me in another thread
http://www.delica.ca/forum/experiences- ... -5152.html but I can excuse either his bad memory or bad conscience.
So, here is the list of the 'bogus' problems the dealer is blaming me for and some explanations:
1. Non-DOT tires.
2. Defective OD solenoid.
3. Burned out left side tailgate 'DELICA' bulb.
4. 1/2" gap between headlights and a front panel.
5. Leaking water pump.
6. Leaking exhaust manifold gasket.
7. Clogged radiator.
8. Malfunctioning thermostat.
9. Faulty master power lock switch.
10. Leaking injector #3.
11. 'home made' DRL module, see the picture below.
The dealer claimed that he was driving this vehicle for 7 month before I bought it and this statement was the major factor for me to make a choice. I thought that 7-month period was sufficient for identifying problems listed below. Recently the dealer repeated his statement and that is why I want to disclose the list of problems that came with the vehicle. The list is not complete but gives you an idea of the original shape of my Delica.
Problem #9 was the only one reported to me and it was quite obvious when the door locks were going on and off while driving. I bought this vehicle in January and finished most of the repairs by the middle of August 2008.
1 - I installed new DOT tires later; still have 1 original left as a spare.
2 - defective OD solenoid was causing the transmission not responding to the OD OFF switch; not a big job replacing it but the problem was not identified by the dealer; instead I was advised that I was driving on 3rd gear while trying OD OFF. Diagnosed by myself with great help of Mystery Machine and replaced by RJD Services.
3 - replacing the bulb would not be a hell of a job but the dealer said that this was not an option: the whole tailgate light panel must be replaced. I replaced the burned bulb myself.
4 - this could not be ignored because at a speed over 70 km/h there was terrible loud wobbling noise; fixed myself.
5 - found and replaced in CVI
6,7 and 8 - identified and replaced in CCAutos. The cooling system were working poorly: the engine was operating below the normal temperature until climbing for several minutes when it was overheating.
9 - replacing the faulty lock switch did not require any mechanical skills; they just could not figure it out; fixed myself.
10 - found and fixed in CCAutos.
11 - caused the turn lights to stop working 70 km away from home. Removed and professionally replaced with the factory made DRL in CVI. Below is the picture of this 'DRL' thingy; you can guess in which way it was wired.
I did not expect the used vehicle to be free of problems but I was badly surprised with the dealer being mad on me because of my discoveries. I provide computer services and I cannot afford barking back on my customers no matter what.
This is my personal experience with Silk Road Autos as of the beginning of last year (2008) and I hope they are making things better now.
This is my last and final contribution to this thread and I am not willing to discuss this post as I am providing the true facts only.
References:
http://www.delica.ca/forum/master-power ... -5372.html
http://www.delica.ca/forum/overdrive-on ... -2129.html
http://www.delica.ca/forum/tail-gate-li ... 04-15.html
http://www.delica.ca/forum/mystery-ratt ... k-665.html
http://www.delica.ca/forum/is-this-the- ... tml#p30476
And here comes a 'DRL thingy' - Silk Road Autos special:[/quote]
