Page 57 of 59
				Posted: Sun Jun 09, 2019 2:43 pm
				by deskinthewoods
				The oil light crapped out on me this week. Flickered on and scared the crap outta me and then went off. I pulled over and checked the oil level: all good. So under the van I went yesterday and reconnected the wire, also the 4WD indicator wire 'cause I was under there anyway. All good :)
- IMG_2964.jpg (27.12 KiB) Viewed 24515 times
I also noticed a puddle in the passenger area after a hard rain a couple weeks ago, after installing the rubber flooring. I guess its always done that but just soaked into the carpet before now. So I tackled the front panel leak issue.
Old caulking
- Water leak 1.jpg (29.52 KiB) Viewed 24515 times
Scraped off
- Water leak 2.jpg (32.63 KiB) Viewed 24515 times
Rust cleaned off
- Water leak 3.jpg (27.96 KiB) Viewed 24515 times
New Butyl sealant
- Water leak 4.jpg (28.28 KiB) Viewed 24515 times
I used this stuff
- Water leak 5.jpg (28.04 KiB) Viewed 24515 times
				Posted: Mon Jul 01, 2019 7:23 am
				by deskinthewoods
				After a heavy rain I still have a small leak...windsheild?...wipers?...windshield washer nozzles?...another day...
				Posted: Mon Jul 01, 2019 7:27 am
				by deskinthewoods
				Replaced the boots on the right CV joints...not too difficult actually...
Step 1. Remove dog
- CV1.jpg (40.6 KiB) Viewed 24423 times
Step 2. Take it all apart
- cv2.jpg (33.61 KiB) Viewed 24423 times
Step 3. remove old boots, clean everything really well, re-grease, re-assemble
- cv3.jpg (21.2 KiB) Viewed 24423 times
Sorry for the lack of photos...
				Posted: Mon Jul 01, 2019 1:24 pm
				by Khrolar
				deskinthewoods wrote: ↑Mon Jul 01, 2019 7:27 am
Step 1. Remove dog
Looking good!
Did you remember to reinstall dog after??
				Posted: Mon Jul 01, 2019 4:15 pm
				by deskinthewoods
				Dog seems to be the self-installing type...
				Posted: Mon Jul 15, 2019 6:59 pm
				by DelicaTele
				tried a new doctor/mechanic in Edmonton...
E-Town = no-such-thing-as-a-mechanic-unless-you-drive-a-rolling-coal-Ford-Dodge-or-GM-P/U...
...but there's many plug-and-play technicians *rolls eyes* !
				Posted: Sun Aug 04, 2019 2:33 pm
				by deskinthewoods
				I took the week off work to rebuild the Injector pump, do an oil change, install new shocks. Figured it would be a two day job to do the IP but I managed to stretch it out to six. Oil change and shocks a bit later I guess...
				Posted: Mon Aug 05, 2019 3:02 pm
				by deskinthewoods
				Installed new rear shocks today.
Procomp. (I have no idea what the old ones are...whatever they are they were DONE!)
- Shocks1.jpg (16.94 KiB) Viewed 24200 times
Sexy! (Canadian colours!)
- Shocks2.jpg (25.92 KiB) Viewed 24200 times
				Posted: Wed Aug 07, 2019 2:20 pm
				by Growlerbearnz
				DelicaTele wrote: ↑Mon Jul 15, 2019 6:59 pm
An L300 is a Dodge D50 Diesel, it's just put on a bit of weight.
				Posted: Tue Aug 13, 2019 9:04 am
				by Vanthony.wa
				ACKO15 wrote: ↑Sat Sep 15, 2018 7:20 pm
Replaced a leaking exhaust manifold gasket and watched our boost jump from a smoky 5psi up to 10 cruising with the option of opening the relief valve when you floor it.
Hey there! I'm in desperate need of swapping out my exhaust manifold gasket. I have the gasket on hand but wondering if you have any tips on doing it myself. Seems strait forward but ppl have mentioned bolts breaking in the head etc
				Posted: Wed Aug 14, 2019 5:39 am
				by Ralph in Winnipeg
				Exhaust manifold bolts breaking is pretty common due to the repeated heating and cooling.  You'll want to soak them with penetrant while hot and let cool.  I'd recommend being prepared for the worst.  Purchase the bolts and nuts, have a drill and taps on hand, bolt extractors (though I generally find they don't work worth a darn) in case you need them.  Take your time, you might have to work the nuts back and forth,  don't put an impact on them and pound away.
Good luck.
Ralph in Winnipeg
				Posted: Wed Aug 14, 2019 6:21 am
				by deskinthewoods
				Worst case: Helicoil threaded inserts. An actually easy solution to a heart stopping problem. (If your heart does stop, the rest is no longer a problem...)
				Posted: Fri Aug 16, 2019 1:10 pm
				by deskinthewoods
				Got the front shocks on today! (also sexy
- Front Shocks.jpg (41.41 KiB) Viewed 24050 times
				Posted: Sun Aug 25, 2019 1:23 pm
				by deskinthewoods
				Today I am hunting down more footwell leaks.
The fresh air intake (easier done with the glove box removed)
- Rain Leak2.jpg (26.53 KiB) Viewed 23900 times
- Rain Leak1.jpg (39.33 KiB) Viewed 23900 times
and the windshield washer posts:
- Rain Leak3.jpg (17.8 KiB) Viewed 23900 times
Too bad the super-duper sealant isn't black but I'll repaint the whole area someday...
- Water leak 5.jpg (28.04 KiB) Viewed 23900 times
Big rain coming Wednesday, says Environment Canada...we shall see...
				Posted: Sun Aug 25, 2019 1:43 pm
				by Khrolar
				Been having starting problems lately. Part of it was the broken wireing, but she still starts slow when she's warm. So I decided to spend Sunday cleaning and to do a refurbishment on the starter motor.
It came out and went back in really easily! Hopefully this fixes my problem, but I bet I'll have to get it professionally rebuilt in October.
- IMG_20190825_100409_compress8.jpg (100.39 KiB) Viewed 23899 times
- IMG_20190825_091533_compress5.jpg (76.08 KiB) Viewed 23899 times
- IMG_20190825_133715_compress41.jpg (131.53 KiB) Viewed 23899 times
