Page 3 of 4
				Re: I'm guilty
				Posted: Mon Mar 02, 2009 4:43 pm
				by MardyDelica
				More Pictures
				Re: I'm guilty
				Posted: Mon Mar 02, 2009 4:47 pm
				by MardyDelica
				More Pictures
				Re: I'm guilty
				Posted: Mon Mar 02, 2009 4:48 pm
				by MardyDelica
				More Pictures
				Re: I'm guilty
				Posted: Mon Mar 02, 2009 8:10 pm
				by psilosin
				those black seats look like Darth Vader!!!
				Re: I'm guilty
				Posted: Mon Mar 02, 2009 8:24 pm
				EnviroImports.com wrote:they are just larger, larger wider components, easier to lift, more stable.more power, more speed,
they are just More of everything, and since they are the newest version,  there are more options for them, both from Mits, and aftermarket.
Noel
Correction
Lifting an L400 spacegear is more difficult to do properly (professionally) than an L300.
This is because the rear end of an L400's axle rides on coil springs.  So you would need longer/heavier rated aftermarket coils, in the front a sub-frame drop down spacer kit and upper 3/4 - lower 3.5 " BJ spacers with shimmed angle.
You also have to carve away a nice chunk more on the L400's front end compared to the L300's.
Lifting the L400 and L300 are identical to lifting a Gen II Montero and a Gen I Montero, which I'd like to add have been around for over 20 years in North America already.
You can buy aftermarket lift kits for both of them in the states.
Simple as that.
				Re: I'm guilty
				Posted: Tue Jun 30, 2009 9:39 am
				by aclarker
				jfarsang wrote:EnviroImports.com wrote:they are just larger, larger wider components, easier to lift, more stable.more power, more speed,
Noel
Correction
Simple as that.
Have you heard of this company
http://www.rocky-road.com/monterosus.html When my L400 arrives I was looking at this company to purchase a lift.  Do you know of a better supply company?
Thanks,
Clarke
				Re: I'm guilty
				Posted: Tue Jun 30, 2009 10:01 am
				by loki
				aclarker wrote:jfarsang wrote:EnviroImports.com wrote:they are just larger, larger wider components, easier to lift, more stable.more power, more speed,
Noel
Correction
Simple as that.
Thanks,
Clarke
parkside auto
				Re: I'm guilty
				Posted: Tue Jun 30, 2009 10:57 am
				by EnviroImports.com
				hmmm, i believe you could put that lift on the L400, but my lift sure is different, but i have ball joint spacers, drop everything brackets, its pretty elaborate. you should take a look at it,  there are alot of similarities but also alot of differences.  but im sure there is as many lift kits for them as there are for 80s chevs, everyone has a different version, but if you lift it , just make sure you check the drive shaft angles and the distance on the slip yoke.  nothing worse than taking out U-joints every month, or flexing your ride and the drive shaft falls out and dings a spline.... been there, done that...
				Re: I'm guilty
				Posted: Tue Jun 30, 2009 5:02 pm
				by mararmeisto
				EnviroImports.com wrote:drive shaft falls out and dings a spline.... been there, done that...
I HATE dinging a spline...
Just out of curiosity, how high are you lifting an L400 when you're doing that? Or a L300 for that matter?
				Re: I'm guilty
				Posted: Tue Jun 30, 2009 5:29 pm
				there are lots of factors, once you lift your van, you should ramp it, or use a BIG jack and blocks to see if when you have the suspension fully expanded if the slip yolk  is maxing out, and see what IS limiting your suspension, like brake line length, shock length, Neither should be the limiting factor in your lift. I would say 3" or higher lift and you really need to look at your limits, but the L300 is the WORST i have EVER seen,  not sure why?, just crawl under one and see your rear drive shaft,  its VERY short and if you then lift the van, your angles go to hell and you really wear out the U-joints, so you should either Shim the rear axel, or put in a double cardin joint, (2 u-joints) at one end, they will cancel  out the bad angle.
most of this is should be either done by someone with ALOT of experience with lifted 4x4s or a profesional shop.
				Re: I'm guilty
				Posted: Mon Aug 24, 2009 3:16 pm
				by chrisfoster1971
				Evening all.. Well I finally made it on here thanks to the invite from EnviroImports after spotting his video on you tube and me falling in love with his ride... Love those alloys
Also mardy Delica looks like a sweet motor as well and a Royal if i'm not mistaken ?
Cracking looking trucks.. just wished we got more lifted ones over here... exchange rate is killing the import prices at the moment. To give you an idea if you were to sell mine at the moment you'd be lucky to get £2000k sterling and mine only has 110k on the odometer
				Re: I'm guilty
				Posted: Tue Nov 17, 2009 12:05 am
				by delicabits
				Was this vehicle from a dealer, private or auction?
MardyDelica wrote:More Pictures
				Re: I'm guilty
				Posted: Tue Nov 17, 2009 12:27 am
				It's his personal L400 Royal Exceed.
As for the montero/L400 lift I should have elaborated.
The rear coils are different. L400 coil diameter is smaller than montero coils. The mounting brackets are smaller as well on the axle so that US lift would not work.
I removed my L400 rear axle last weekend and measured the mount points, frame, axle, coils, brake booster, panhandle bar, etc...
I got a 2.5" lift that I put together and will install it hopefully this weekend. When it's on, I'll post the results.
				Re: I'm guilty
				Posted: Tue Nov 17, 2009 4:24 am
				by delicabits
				I understand it is his but did he buy it from a dealer in Japan, auction or private?
				Re: I'm guilty
				Posted: Tue Nov 17, 2009 9:15 am
				by MardyDelica
				hi, i did buy this L400 from the auction long time ago:
Cheers;
