Page 3 of 3
				Re: -10 & driving with 15w40 ?  CHANGE YOUR OIL !!!!!!!!!!!
				Posted: Mon Oct 17, 2011 12:07 am
				by nxski
				I'm assuming that for primarily Lower mainland use with only the occasional start below -10 that 15W-40 full synthetic should be fine!?
				Posted: Mon Oct 17, 2011 1:07 am
				I use 5W40 from Nov - Mar or 5,000km-ish for the winter oil change interval.
You will notice a difference even at 0 cel between 15w40 and 5w40.
				Posted: Mon Oct 17, 2011 8:42 pm
				by Mr. Pistachio
				After a winter in the East (Ottawa) I can say that for those -30 morning the 0w40 was the best choice I could make! Engine would start (almost) like in the summer (L400). It's a world of difference!
				Posted: Tue Oct 18, 2011 2:38 pm
				by Firesong
				I use 0/40 in the winter.
Come November depending on the temp's I do the switch to synthetic.
In the summer I use dino oil 15/40
In Saskatchewan I don't mess around. I need my vehicle to start whether it's
plugged in or not.
Good batteries help too. (two of them)
FS
				Posted: Tue Oct 18, 2011 6:05 pm
				by nxski
				I just bought the Royal Purple 5W-40 synthetic oil. I was at Lordco and they told me that I couldn't buy it on big bottles (like you can with the 15W-40) which means instead of spending just under $100 for 6.5L you end up spending over $200. The solution was to complain about having to buy 7 bottles.
  They ended up knocking the price down by about 2/3, from $29.36 to $9.197.
				Posted: Wed Oct 19, 2011 12:10 am
				by jwfchase
				nxski wrote:... instead of spending just under $100 for 6.5L you end up spending over $200. ...
For one DIY oil change?!
				Posted: Wed Oct 19, 2011 8:15 am
				by nxski
				jwfchase wrote:nxski wrote:... instead of spending just under $100 for 6.5L you end up spending over $200. ...
Yes, for 1 DIY!
				Posted: Wed Oct 19, 2011 12:52 pm
				by nxski
				So we've established that 15W-40 isn't as good in the winter. How does 5W-40 work for summer months?  Would the only concern be leaking?
				Posted: Wed Oct 19, 2011 1:04 pm
				by thedjjack
				Since you have to change your oil every 3 months or 4000km (Unless you have a bypass system).  Why not run the oil for the conditions.
				Posted: Wed Oct 19, 2011 1:14 pm
				by nxski
				I ask because I won't be driving very much this winter and will most likely be installing a bypass system...
				Posted: Wed Oct 19, 2011 1:19 pm
				nxski wrote:So we've established that 15W-40 isn't as good in the winter. How does 5W-40 work for summer months?  Would the only concern be leaking?
Plenty run 5W40 synthetic year-round.
				Posted: Wed Oct 19, 2011 1:34 pm
				by thedjjack
				nxski wrote:I ask because I won't be driving very much this winter and will most likely be installing a bypass system...
Yes but oil starts to break down the minute it is run through the motor once....that is why you get a date or mileage for the next oil change....Oil is cheep engines are not!!!
I personally like a thicker oil in very hot conditions at start up when the oil is cold....
				Posted: Wed Oct 19, 2011 1:42 pm
				by nxski
				True, I'm thinking every 10,000km with a fram filter, bypass and royal purple full synthetic. Even doing it myself that's not a cheap oil change!
				Posted: Wed Oct 19, 2011 9:31 pm
				by bassnailer
				(sorry for the hijack), so I am due for an oil change, and I'll be leaving in a couple of weeks for the interior for hunting. But for the remainder of the winter I will be mostly in Vancouver with a few trips to the mountains and Princeton as well.  Do I use synthetic, 5w30, 0w30?  I don't know where to start....too many options!
				Posted: Wed Oct 19, 2011 9:50 pm
				by nxski
				From what I've been told (I have very similar plans for travelling this winter) 5W-40 would be the one to choose...
