Re: I finally gave in...
Posted: Wed Nov 11, 2009 10:35 pm
				When we first bought out first L400 they both arrived within 5 weeks of each other. I don't think I slept for 2 months.
 . By the way if it has airbag it will have ABS. Those two options are usually always found together. Having said that there is only one thing I am sure of when it comes to Delicas and options and that is " there is no such thing as a low roof LWB L400 4x4". I would need photographic evidence to believe that.
And not this kind of photographic evidence.....Look carefully at the shadow of the car
One of our members trying to trick us with photoshop..
Interesting about having the running lights on during the day. That is a good safety initiative. They should institute that here. Especially for motor bikes.The lights do have a normal "on" setting which forces them to stay on in daylight as well as an auto setting which detects if they need to be on or not. The CD stacker should be under the front seat. There should also be a draw under the front passenger seat. Very handy to store stuff in. The compass will probably need to be reset. Just find a roundabout and as you enter the roundabout, press and hold the "set" button as you do a couple of loops and it will find it's bearings. It will need this done whenever you disconnect the battery. There will be lots of buttons to play with . Cheers..
