Page 2 of 2
Re: Won't turn over, help please. all fixed ,thanks
Posted: Wed Aug 05, 2009 4:15 pm
by RaddCruisers
Just a note that both the starter relay and glow relays feed through a fusible link at the battery(s) and if that link is broken or contacting poorly, you will get no glow, no crank, no start (unless you have a manual trans, or jumper the solenoid on the starter to engage it) ...
~John
Posted: Wed Aug 05, 2009 4:36 pm
by Luna-Sea
Right on! 8-)
Re: Won't turn over, help please All fixed!
Posted: Thu Aug 06, 2009 6:55 am
by Spearo
visotzky wrote:Thanks to a Call to Glen at CCAutos , My deli is all good again. turns out one of the connectors coming off of the + terminal was corroded.
Thanks everyone for your help. I learned alot.
Val
Occam's Razor strikes again.
Glad it's running :)
Posted: Fri Aug 07, 2009 11:05 am
by Blackberry
visotzky wrote:... luckily it's a standard and got some help to push me down the hill to start via compression.
Interesting. I've a 5spd as well and had been wondering if it was possible to do so with such a high compression engine. What gear did you bump-started it in?
Thx!
