Re: Electric Fan
Posted: Sat Aug 08, 2009 11:18 am
I think you'd only use the A/C fan without the compressor, that way you'd have 2 fans instead of one to move more air. That's how I understood the mod anyway...
Forum for Mitsubishi Delica owners and enthusiasts.
http://delica.ca/forum/
I am about to go out and do that exact mod right now. All I have to do is bypass the fan relay so it runs continuous with the key ondelicat wrote:I think you'd only use the A/C fan without the compressor, that way you'd have 2 fans instead of one to move more air. That's how I understood the mod anyway...
Ok that was fast (really a 10 minute job) however not quite as easy as I had hoped. The main power to the fan relay is notModsqwad wrote:I am about to go out and do that exact mod right now. All I have to do is bypass the fan relay so it runs continuous with the key ondelicat wrote:I think you'd only use the A/C fan without the compressor, that way you'd have 2 fans instead of one to move more air. That's how I understood the mod anyway...
and when I hit a big hill turn off the ac. The fan will keep running and Bob's you uncle! I'll report back on how it worked after this
trip.
Andy Wilson
jfpdelica wrote:Let me get this straight. I'm going to turn on the AC, along with the mech. fan (which I have no control over), alternator (when it is required). And you think that all of that isn't a lot to run? I would rather have the alternator running only, to limit the amount of drag on the engine. Now, I don't have a overheating problem, just a lack of power to operate all of the things that were suggested to keep my vehicle in its operating temperature. Cheers
jfpdelica wrote:Sorry for me not understanding this quite yet. If you have three belts operating at the same time, (alternator,mechanical fan, AC) would that not mean that there is a huge lose of power when compared to a single alternator of larger size with a electric fan? Maybe my logic has failed me? Jeff 8)
the draw off the Taurus electric fan was very minimal. Definitely not as much of a draw when compared to the mechanical pull of the fan clutch.Modsqwad wrote:If you remove your engine driven fan you will remove the energy required to drive it but will increase the load on the charging system at least as much to produce enough power to drive the electric fan you replace it with.n
An interesting question in efficiency ie engine driven fan HP/CFM against electric Amps/CFM without data its hard to pin down.jfarsang wrote:the draw off the Taurus electric fan was very minimal. Definitely not as much of a draw when compared to the mechanical pull of the fan clutch.Modsqwad wrote:If you remove your engine driven fan you will remove the energy required to drive it but will increase the load on the charging system at least as much to produce enough power to drive the electric fan you replace it with.n
If you feel that your engine fan is wimpy, then the clutch is not engaged. It will only engage when there is sufficient heat blowing over it from a hot rad - so the rad must be working properly, along with the rest of the cooling system. These fans can move a lot of air when the clutch is fully engaged.jfarsang wrote:I disagree.RaddCruisers wrote:Electrics are FAR less efficient than engine driven fans - they simply cannot move anywhere near the same amount of air as an engine driven unit will.
The stock clutch fan on my 2.5 was like comparing a little 2AA battery fan and the Taurus electric fan being an industrial blower.
When I went into a few water crossings, I'm able to turn it off completely so it won't soak the engine compartment, get water in everywhere and if by any chance I end up getting stuck in the water with the engine running I'll have less danger to hydrolock it although you'd have to really bury the thing in water with the engine running in my opinion before this was an issue since the intake is away from the fan.
I prefer the electric. You're driving anyways, so the battery/alt is powering/charging it. It's lighter and the obvious is that there are no mechanical parts. Less drag/belts, etc...
Advantages and disadvantages I guess.
I'm putting on on my L400 as well.
