Re: Strange Sound
Posted: Tue Mar 03, 2009 6:45 pm
also check your crank shaft pulley bolt.
Yesterday, I heard a low-end rattle at load and I originally thought it was an exhaust leak.
It turned out the person who did the timing didn't torque down the crank bolt enough (125 ft lbs).
The bolt worked it's way loose, and the key on the crank shaft worn a groove in the pulley which loosened it creating that 'noise'.
I really should have recorded it because I asked around and did some research.
Apparently it's a common issue if not tightened down properly.
That will lead to a completely blown engine. Good piece of rock.
Keep your ears in tune with your engine.
If something is a miss. Don't keep driving it.
If I would have driven mine another mile or another day, I may have been looking at a $4,000 engine replacement job instead of a $400 pulley replacement job.
I got really lucky.
Head's up.
I got really lucky.
Head's up.
