Re: Torsion Bar Adjustment
Posted: Mon Mar 17, 2008 3:14 pm
Another option is to modify the door card. (sliding door trim panel - whatever you guys call it??)
The door card is hardboard (pulp wood/composite board?? translate if you can please?) covered in vinyl/carpet. On one L300 I modified for a friend with some WIDE wheels, I removed the door card and peeled back the vinyl on the bottom left...then cut away the hardboard in the area that the tyre rubbed. If you cut carefully, you can remove the exact amount needed without cutting through the vinyl. You are left with a flap of vinyl in the bottom left corner....but read on!
I then refitted the panel onto the door using all the normal clips most of the way around and used spray glue (proper carpet adhesive, not that art 'spray mount' crap!) to fix the 'flap' of vinly directly onto the door. I folded all the edges up (like a hem) and when finished all you could see was a ridge in the door card where the hardboard was no longer there.
The result - the door slides open really nicely now!
I'm not sure what material is on your door card, but the panel I did this on was vinyl along the bottom. I have carpet on the lowerpart of the door card on the Mystery Machine, but I imagine it would still be OK to do this??
Have a look for yourself? Another possibility! (I have a third option too....but try these two first and see how you get on?)
