Page 2 of 2
				Re: Installed EGR Blanking Plate - Sputtering - UPDATE - FIX
				Posted: Mon Sep 19, 2011 7:04 pm
				by 92Nicopolis
				I never thought of it that way before
  I dont know the answer but sound like a good question
				Posted: Mon Sep 19, 2011 7:10 pm
				by Fishtank
				BushRatt wrote:Ok...so I have a question...I was told that you can just cut the hose on the EGR valve and plug it. Is this correct? If so why install the blanking plates?
Thanks, BushRatt.
Yes you can do this.  I guess the best reason to install plates would be to clean up the engine area and take advantage of a great place to install an EGT probe (L400 anyway).
				Posted: Mon Sep 19, 2011 7:57 pm
				by BushRatt
				Ok thanks. So do I plug both hoses? And what is an EGT probe?
Thanks, BushRatt.
				Posted: Mon Sep 19, 2011 9:13 pm
				by Fishtank
				BushRatt wrote:Ok thanks. So do I plug both hoses? And what is an EGT probe?
Thanks, BushRatt.
Just plug any hose leading to the EGR.  EGT = Exhaust Gas Temperature probe.
				Posted: Mon Sep 19, 2011 9:43 pm
				by legionnair
				You can just unplug the vaccum line of the EGR and plug it but mine was this way and it was not sealed enough, so when I did the block off plates there was carbon inside the intake manifold.  So your best bet is to do the proper block off
And then you can put I your EGT probe
Dustin
				Posted: Tue Sep 20, 2011 1:32 pm
				by yojimbo
				If the EGR valve is stuck open from crud, then it needs blocking off, regardless of the vacuum line being on or not.  If you are getting the urge to disable the egr through poor performance, then it being stuck is quite likely.
				Posted: Tue Sep 20, 2011 1:35 pm
				by yojimbo
				gsaruk wrote:
**********UPDATE**************
It seems like the sputtering was the pop off valve (thanks, Luna-Sea).
LOL, you're welcome.
				Posted: Tue Sep 20, 2011 11:08 pm
				by Luna-Sea
				Stoked you got it figured out.
Game point on this thread
have to go to Yojimbo though.
(Across the pond nod and thumbs up.)
                       Right On!
				Posted: Wed Sep 21, 2011 11:14 am
				by gsaruk
				Luna-Sea wrote:Stoked you got it figured out.
                       Right On!
My bad! Thanks, Yojimbo.
				Posted: Wed Sep 21, 2011 1:00 pm
				by yojimbo
				No worries, it made me laugh actually
