Looking for help finding the best places to tie into my cooling system on my 91 Delica to cool my turbo. Have a turbo with a water jacket.
The second picture with the oily line is a line off the discharge side of the water pump and goes to the heater. I thought I could tie into this as the source. Can anyone tell me how this line is attached? Does it have an O-ring and just slip into that housing?
The first picture is the back left side of the head where a heater line returns. I thought this would be a good place to run a return coolant line from the turbo.
Any thoughts or suggestions?
Thank you!
Cooling lines for turbo
- robinimpey
- Vehicle: 1991 Starwagon
- return.JPG (41.9 KiB) Viewed 2268 times
- source.JPG (88.01 KiB) Viewed 2268 times
Re: Cooling lines for turbo
The manual I have only shows an oil cooled turbocharger. Pages 12/13 L300 Intake & Exhaust manual (book 15)
Correction: Jesse points out that water and oil lines are shown. So I am insure about which version this is supposed to be.
If you go to the L300 Dedicated Reference Library; click on L300 Shop Manual Downloads; Intake & Exhaust Manual; Page 15-12 is an exploded illustration of the intake and exhaust manifolds. Items 10 & 11 are the water feeds for the turbochargers that came with them. Hope this helps.
Falco, he does not have a post-93 water cooled cylinder head ~ so your reference doesn't apply here.
Robin, this is what you are seeking. Just snapped the pictures of a pre-93 oil cooled 4D56T on an engine stand.
Feed line:
1. the heater line is a press fit with an o-ring into the thermostat housing. You can splice into there for the feed line to the turbo.
Return line:
1. tee back into the heater line (wraps around the rear of the valve cover)
or
2. run a braided line down to the block (pics 5/6) where a 12mm bolt leads into coolant passage
Would be a good idea for mod's to merge these two threads as they are related: http://www.delica.ca/forum/turbo-advice-12729.html
Feed line:
Return line:
or
- cooling1.jpg (186.92 KiB) Viewed 2172 times
- cooling2.jpg (210.15 KiB) Viewed 2172 times
- cooling3.jpg (242.23 KiB) Viewed 2172 times
- cooling4.jpg (242.22 KiB) Viewed 2172 times
- cooling5.jpg (264.71 KiB) Viewed 2172 times
- cooling6.jpg (171.75 KiB) Viewed 2172 times
Robin
A reference point below, you can see the outlet (at the thermostat housing) -> Turbo inlet on a 4M40 an inch beside the heater line (like the 4D56T)
The point of entrance on the L300 thermostat housing where the solid heater line presses into, is in a similar position as the 4M40 outlet.
An A/C shop may have the tools required to either utilize the existing solid heater line/splice off to the turbo, or fabricate a new line that goes from the thermostat housing direct into the turbo and then out continuing along to the heater line <-> hose connection.
Jesse
Jesse
- 4232227431_5c58068ca3_z.jpg (72.17 KiB) Viewed 2140 times
