L300 Stretch updates
thedjjack
Vehicle: 1989 L300 HITOP!!
Re: L300 Stretch updates
Post by thedjjack »
disk breaks me hopes!
What will you do with the welded subframe to the unibody ?
Super Exceeded
Vehicle: 1993 L300S
Post by Super Exceeded »
jfarsang wrote:What will you do with the welded subframe to the unibody ?
Well I'ma gunna do what I did every other time. CUT first, figure the rest out after. It will work, I don't have any other options....
Super Exceeded
Vehicle: 1993 L300S
My toyota land cruiser has arrived. Let the SAS Begin..
Well after I strip it off the truck, replace the drum brakes for disk, replace the seals and change the gearing. But like I say, it's 80% done with 80% to go.
nxski
Post by nxski »
Is the SAS in place now? Do you have an estimated time of completion? I assume we won't be seeing you at the November meet or is there a chance you'll be mobile by then? 4 runners are allowed too...as long as you don't park too close to the Deli's (maybe go and overshadow the Pajero's) :-D jk
thedjjack
Post by thedjjack »
nxski wrote:Is the SAS in place now? Do you have an estimated time of completion? I assume we won't be seeing you at the November meet or is there a chance you'll be mobile by then? 4 runners are allowed too...as long as you don't park too close to the Deli's (maybe go and overshadow the Pajero's) :-D jk
X2...just park the 4runner out of site or throw a car cover over it :-D
Super Exceeded
Vehicle: 1993 L300S
Current state of the SAS is as pictured. I will be holding of until I get me nwe engine and do the engine swap and SAS at the same time..
Luna-Sea
Post by Luna-Sea »
I am among the many in the eagerly anticipating audience for the
next phase. PLEASE take lots if pics.
Ridiculously phenomenal work so far.
Right On! 8-)
Super Exceeded wrote:Current state of the SAS is as pictured...
There seems to be a complete lack of a vehicle in that image.
What's the timeframe on an engine? Also, what's an "nwe" engine?
There seems to be a complete lack of a vehicle in that image......
Nice looking truck, 'though.
Super Exceeded
Vehicle: 1993 L300S
For those of you that don`t know a NWE engine is one that is new to me, but not brand new!!!!!! Just got me aline od a 350 with tranny so with any luck I can get it all here, get er cleaned up and installed.
Hope to put stretch on the road fo rhe Deli meet at IKEA (Weather depending)
thedjjack
Post by thedjjack »
Gas 350 - V8??? :-D :o :-D :o That will get the strech moving....
Make sure you get a newer Vortex or something if you are going this way....
yum. how's the axle/cv condition on the donor axles?
Super Exceeded
Vehicle: 1993 L300S
thedjjack wrote:Gas 350 - V8??? :-D :o :-D :o That will get the strech moving....
Nope going with a simple carb. Stretch won`t need all the power of the fancy electronics, and there is so much less that can break when you`re out of `town`
The axles look in great shape, but will tear them down and have a good look.
A
thedjjack
Post by thedjjack »
I would go with a simple throttle body like a early Vortex...
You can keep a simple carb in the spares if you have issues. Injected motors run so great and you will need electronics unless going with POINTS :o
are you going to bolt all this under the delica Unibody? I would consider building a chassis with the axles, motor, etc mounted and lower the body on...adds a few hundred pounds but makes sense to me...
Toyota axles can handle mild v8...but you should up the u joints!!!
What transfer-case/transmission you going with?
