Can anyone name this clip? I found it when I was fiddling with my TPS and it is so loose it just slides off. If I hit a bump it would probably fall off. Not sure what it goes to or is for. Just wondering if I can cut it off and get a slide on connector from CT to replace this one. Thanks
Craig
What does this clip do?
- CREGAN
- Optimized-IMG_7815.JPG (42.67 KiB) Viewed 2512 times
- Optimized-IMG_7813.JPG (48.76 KiB) Viewed 2512 times
- Rising Sun Auto Import
Re: What does this clip do?
That's the oil pressure switch connection.
Most of the time old one is too loose to hold.
Steven
Steven
- 214.JPG (86.8 KiB) Viewed 2508 times
- CREGAN
So Steven can I just replace it with any old slide on clip? I was going to cut the end off and crimp it into a new slide on clip.
Craig
Craig
psilosin
- Vehicle: L400
I did exactly that Craig. Just crimped on a new female spade connector...10 seconds and good as new.
X2.psilosin wrote:I did exactly that Craig. Just crimped on a new female spade connector...10 seconds and good as new.
- CREGAN
Right on - Thanks guys. Finally something I know I can do!
Craig
Craig
- CREGAN
I did it and it worked out no problem. Thankspsilosin wrote:I did exactly that Craig. Just crimped on a new female spade connector...10 seconds and good as new.
