turtle WVO install pictorial
- after oil
hi
turtle is done! the pictures mostly say it all. a few deets though: the return valve is plumbed to another valve i can turn by hand to select return to tank, or loop back to IP, through an out port in the filter. i took off the hand primer and capped the filter again b/c i think the primer was leaking air (i suspect the filter assy still is still leaking air)
the tank is 120l aluminum w/ a baffle, bolted into the rear sway bar bolt holes.
- heat exchanger.. green lines are coolant. there is a glow plug preheater controlled by the thermocouple
- P6080750.jpg (114.15 KiB) Viewed 17665 times
- the return valve
- P6080752.jpg (96.18 KiB) Viewed 17665 times
- temporary plastic wvo line, replaced with fuel line, in from the back. the three way manual ball valve is at bottom center, but cant really see it
- P6080753.jpg (115.64 KiB) Viewed 17665 times
- tank w/ wvo designs hot stick. not plumbing the heated pickup yet
- P6130750.jpg (96.43 KiB) Viewed 17665 times
- will it fit?
- P6140749.jpg (104.86 KiB) Viewed 17665 times
- yep!
- P6160760.jpg (97.62 KiB) Viewed 17665 times
- after oil
Re: turtle WVO install pictorial
- P5190753.jpg (84.35 KiB) Viewed 17664 times
- P7020895.jpg (82.63 KiB) Viewed 17664 times
- P6160761.jpg (107.27 KiB) Viewed 17664 times
- P6170762.jpg (109.31 KiB) Viewed 17664 times
- delicat
Congrats!
It was only a matter of time with you, we all knew it was coming!
Nice custom install, I especially like how you mounted and attached your tank, great idea!
Enjoy the grease!
Mr. D
Enjoy the grease!
Mr. D
- Vehicle: -
Well done after-oil!
Are the clear coolant hoses rated for high temperatures?
- after oil
thanks...fexlboi wrote:Well done after-oil!
maybe they aint rated for high temps.. but theyll hold... i think...
ive used them on other installs with no problems, but before my drive through the Nevada desert this summer ill put real heating hoses on there..
how much pressure is a cooling system anyhow?
- Vehicle: -
Just read a few times on other forums that people running into problems with the clear hoses as they are rate for around +65°C max. If the temperatures rises the rubber gets pretty soft and they might slip off the barbs even with hose clamps.
Service Specs. for the 4D5:
Items;__________________________________________________Standard Values;____________________Limits;
High pressure value opening pressure of radiator cap kPa:_______74 - 103___________________________64
Range of coolant antifreeze concentration of radiator % :________30 - 60
Thermostat:
Thermostat:
- Valve opening temperature of thermostat *C:_____________82 +/- 1.5
- Full opening temperature of thermostat *C:______________95
- Valve lift mm:_______________________________________8.5 or more
- after oil
First highway trip yesterday from comox ferry to Vic and back: ALL GOOD
im pretty sure the filter assy is still leaking air. on the way down at times there was a bit of hesitation (maybe) but on the way back did the speed limit or more, climbed the Malahat no problem!!
Looks great Ari !
psychadelica
- Vehicle: L400 Series II Super Exceed
What's your speed over the Malahat in the L300? If I am on my own I have to drop to about 60kph and with a car load of people, man, I must drop to 40 or 50kph on the steeper parts.
- after oil
sort of depends where.. heading north, i can keep 70-80 going in the beginning, and down to around 70 coming up by the shawnigan lake turnoff
Jordan
- Vehicle: 89 low roof L300
Great install, every aspect of that vehicle is so beautiful.
What kind of switch is this?
- after oil
its the brains of the system. its a 3 way toggle, 1 diesel, 0 veg - glow plug, 2 veg + glow plugJordan wrote:Great install, every aspect of that vehicle is so beautiful.
theres relays and a micro chip in there that delays the switching of the return valve to allow for a good purge.
Jordan
Who makes it? What is the purge time?after oil wrote:its the brains of the system. its a 3 way toggle, 1 diesel, 0 veg - glow plug, 2 veg + glow plugJordan wrote:Great install, every aspect of that vehicle is so beautiful.
Jordan
Does the glow plug cycle to keep the oil at a certain temp or does it stay on? What temp does your oil get to?
