Power steering fluid
nxski
Post by nxski »
I'm trying to figure out if I have enough power steering fluid in my mightymax. There is a dipstick of sorts but it has no markings on it. Anyone know how I could figure this out?
lrp374
Vehicle: 91 Super Exceed
Re: Power steering fluid
Post by lrp374 »
Let's see a picture.
nxski
Post by nxski »
Coming soon to a computer screen near you...
= my iphone is syncing, hold tight :-D
nxski
Post by nxski »
Here they are...
power steering 1.jpg (67.28 KiB) Viewed 4415 times
power steering 2.jpg (73.03 KiB) Viewed 4415 times
power steering 3.jpg (74.16 KiB) Viewed 4415 times
nxski
Post by nxski »
There are many odd noises coming from the truck 2 of which are quite concerning.
- One is that the right front wheel makes a sound as if it's seizing whenever it hits a big bump, it's very loud!
- The other is why I ask about power steering fluid (or potentially a belt!?) when I turn the wheel the engine starts to whine and I can feel a strange vibration in the wheel that correlates with the whining. When the wheel is fully turned to one side the engine will start to rev at about half of what it usually revs at.
lrp374
Post by lrp374 »
That looks just like the Delica reservoir. Mine has a notch and min/max info. If this one doesn't take the one from your van and compare.
nxski
Post by nxski »
Turns out it has some very faint lines on it, and the power steering fluid was so low it didn't even register on the stick. I filled it up and the problem seems to have been solved but I'll find our for sure when I do my next cold start.
Thanks for the help!
nxski
Post by nxski »
Ps. It should be similar to the delica. It's essentially a dingle cab strata with an l400 gas engine.
you have the small lines on the dipstick. will say which one is for hot and which one is for cold.
nxski
Post by nxski »
The hot and cold markings appear to have worn off, there are only 2lines so as the engine was hot I filled to the upper line and all seems to be good. It's in the shop getting a once o er for some other thongs too so hopefully they'll give the power steering a clean bill of health
nxski
Post by nxski »
And a clean bill of health is what it got. None of the problems are detrimental to the function of the vehicle!
thedjjack
Vehicle: 1989 L300 HITOP!!
Post by thedjjack »
nxski wrote:Ps. It should be similar to the delica. It's essentially a dingle cab strata with an l400 gas engine.
Wow, Dingle Cab those are rare!
nxski
Post by nxski »
I can't tell anymore if I have fat fingers, autocorrect is kicking in or more likely a mixture of the two :-D
thedjjack
Post by thedjjack »
Is there a beer in one of your hands?
nxski
Post by nxski »
Not yet, driving home now. There will be lots of booze when I head out clubbing tonight though :-D
