Mounting the snorkel. A whole lot more difficult than I thought condsidering that when you cut the wheel well bigger, the stock snorkel no longer fits as it was meant too... Arrrrrrrrrrrrrrrrrg will nothing go smoothly!!!
L300 Stretch updates
- Super Exceeded
- Vehicle: 1993 L300S
Re: L300 Stretch updates
Light bar back on, (not yet connected)
The maiden road tripSuper Exceeded wrote: Arrrrrrrrrrrrrrrrrg will nothing go smoothly!!!
- thedjjack
- Vehicle: 1989 L300 HITOP!!
You mean the maiden road trip 2.0?jfarsang wrote:The maiden road tripSuper Exceeded wrote: Arrrrrrrrrrrrrrrrrg will nothing go smoothly!!!
How much of the vehicle has to have been changed for it to be a 'maiden' again?thedjjack wrote:You mean the maiden road trip 2.0?jfarsang wrote:The maiden road tripSuper Exceeded wrote: Arrrrrrrrrrrrrrrrrg will nothing go smoothly!!!
Basically everything
- thedjjack
Same drivernxski wrote:Basically everything
- Super Exceeded
Not a maiden.thedjjack wrote:Same drivernxski wrote:Basically everything
- Super Exceeded
Snorkle attached.
- 0417111810a.jpg (68.19 KiB) Viewed 4820 times
- 0417111809a.jpg (72.61 KiB) Viewed 4820 times
I can't see the Toyo axle under there !
- thedjjack
Hino 6x6 on BC 4x4 might get parted out...good source for a bigger engine....
http://bb.bc4x4.com/showthread.php?1637 ... ost1069036
Did you ever get the front end sorted out for drivability ?
- Super Exceeded
Nope, but it looks like I've got a line on an old Toyota land cruiser front end.
fmande
- Vehicle: 97 TD exceed SWB
I have also been thinking that maybe a transplant is in orderthedjjack wrote:Hino 6x6 on BC 4x4 might get parted out...good source for a bigger engine....
http://www.ebay.com.au/itm/AEC-Militant ... 1c1cb4a6a8
http://www.ebay.com.au/itm/ARMY-TRUCK-G ... 19c6809a65
regards David
regards David
- Super Exceeded
Just bought an old Toyota land cruiser with you guessed it A SOLID AXLE. So as soon as we get it out check that the gears are good and the right ratio, Stretch will get its SAS..
