96 Delica L400 SPACEGEAR Diesel 142k Auto arrived *SOLD*
- MardyDelica
1996 L400 Delica Spacegear 2.8L intercooler turbo Diesel, 4m40 engine, Auto, 4x4, Exceed model, white color, L400, has 142,000 kms with flair on it.
This Nice L400 has No Rust
aftermarket wheels, aftermarket performance rear leaf spring & replacement aluminum wheels , hard to find all combination package for this L400 , this is your chance to own L400 with fully loaded accesories on it.
Dual sunroof all works & tested in japan, also with rear spoiler original; rare to find nice Exceed white L400 delica.
Things will do to this lovely nice White Exceed L400:
install brand new 4 tire all terrain tread pattern mud & snow
install new block heater
4 new pro comp 9000 series shock heavy duty one
brand new front & rear brake pads ( made in Japan pads)
machine front & rear rotors,
repack front hub both side
new front stabilzer link
new e-code headlight with led DRL headlight
New transmission Filter & fluids
new oil change & all fluids has been change front to rear
new front & rear reflector
brand new L400 antifreeze water bottle
new water pump
new thermosthat
All new fan belt 3 pcs
replace new front injection pump seal
Clean & pre set the 4 injector
New valve cover gasket
will pre- set TPS sensor timing to have a proper & smooth shifting of your L400 that will runs like a car
so buyer beware. thru us we only sell mostly fully service vehicle to give full customer satisfaction &
For inquiry, pls feel free to contact me, will more than happy to answer all your question.
This include 1 year or 12,000 kms power train warranty whichever comes first
SOLD
Stock # PE8W=142K
Amazing Auto Imports LTD
Any questions please call me:
604-247-2111 / 604-720-6144
thanks,
new water pump
new thermosthat
SOLD
Stock # PE8W=142K
thanks,
- DSCN3089.JPG (55 KiB) Viewed 8153 times
- DSCN3092.JPG (71.3 KiB) Viewed 8153 times
- DSCN3091.JPG (48.57 KiB) Viewed 8153 times
- DSCN3093.JPG (44.67 KiB) Viewed 8153 times
- DSCN3094.JPG (45.74 KiB) Viewed 8153 times
- DSCN3100.JPG (66.6 KiB) Viewed 8153 times
- MardyDelica
Re: 96 Delica L400 SPACEGEAR Diesel 142k Auto $10,800
More pictures;
- DSCN3104.JPG (73.52 KiB) Viewed 8152 times
- DSCN3108.JPG (78.78 KiB) Viewed 8152 times
- DSCN3103.JPG (77.93 KiB) Viewed 8152 times
- DSCN3105.JPG (84.41 KiB) Viewed 8152 times
- DSCN3118.JPG (75.69 KiB) Viewed 8152 times
- DSCN3124.JPG (85.09 KiB) Viewed 8152 times
- MardyDelica
more pictures;
- DSCN3130.JPG (80.66 KiB) Viewed 8150 times
- DSCN3129.JPG (88.62 KiB) Viewed 8150 times
- DSCN3128.JPG (87.13 KiB) Viewed 8150 times
- DSCN3115.JPG (87.14 KiB) Viewed 8150 times
- DSCN3125.JPG (73.47 KiB) Viewed 8150 times
- DSCN3126.JPG (60.91 KiB) Viewed 8150 times
- sasquatch-hunter
- Vehicle: 2 Delica
Hi Mardy,
How are you? So for this 1996 Space Gear, is it a series one or series two? Does it have the winter package and rear LSD?
cheers,
seb
cheers,
seb
- MardyDelica
hi sebastian,
this is series 2 now as many 1996 model L400 has throttle handle now. like L300 old type. which is nice.
as per the LSD i have not seen any LSD so far as the L400 has awd option.
i presume thru my understanding is that they dont need as this L400 has awd. not like L300 dont have awd.
so thats the big difference.
so i guess there is no used of putting lsd on this as this L400 has awd option
cheers;
cheers;
- Vehicle: -
I assume Sebastian is referring to the second generation l400 which apparently got release in 1996:
Correct me if I'm wrong, but this l400 looks like every other l400 in Canada to me. Mardy, can you shed some light on when it is possible to buy the facelifted l400s?In 1996/1997 the Delica Space Gear was upgraded with a facelift model. The upgrade is mostly cosmetic with changes to the lighting clusters and front bodypanel, with the integration of a moulded bumper in place of the original three section bullbar. The engine was upgraded with an electronic control type distribution type jet pump and an electronic sidestep was made standard on the higher specification versions.
- deli1733
The fog lights are in the actual body, but i thought that they lost the tube bull bars.
All series II Spacegears look different. The body moulding in the front bumper/quarter panels are different.
Production of Series one continued alongside Series two.
Because the series two has a lower approach angle, more fibreglass up front and a more complicated electronic injection pump, many favor the series one (better approach angle/less body moulding/simple injection pump) over it.
Series Two picture :
- MardyDelica
ah i see this is what u mean sorry sebastian.
as the 1996 model L400 some feature are different
cheers;
cheers;
It looks like the L300's get a facelift in 1998 as well. Any chance they'll be making a comeback?
- MardyDelica
Re: 96 Delica L400 SPACEGEAR Diesel 142k Auto On Hold
Hi, This L400 is on HOLD
Thank you very much Sebastian
really appreciate it:
Cheers;
Cheers;
- nvanadm
I think the L300's were produced until 2007 or 2008. They don't need to make a comback, they can still be "new" to us until 2022nxski wrote:It looks like the L300's get a facelift in 1998 as well. Any chance they'll be making a comeback?
If my L300 dies in the next 11 years...i'll just get another 15 year old L300
Sorry Mardy to be a little off topic here...
I just meant that the L400's seem to be more popular now for importing despite the fact that they were both being made in 1996 and in my opinion the L300 looks cooler.nvanadm wrote:I think the L300's were produced until 2007 or 2008. They don't need to make a comback, they can still be "new" to us until 2022nxski wrote:It looks like the L300's get a facelift in 1998 as well. Any chance they'll be making a comeback?![]()
If my L300 dies in the next 11 years...i'll just get another 15 year old L300![]()
I also apologize for getting off target Mardy...
- MardyDelica
- MardyDelica
