Tail pipe rattle at idle
Jay Pea
- Vehicle: 95 Space Gear
My tailpipe has a bad rattle against the body at idle. Is there a fitting that I can buy to cushion the impact around the tailpipe? Or is there another solution?
Re: Tail pipe rattle at idle
Something is loose. Establish what is loose and tighten it back up. Could also be mounts.
Go to a muffler shop. They will fix it. Probably a loose/old hanger.
- dfnder
- Vehicle: '91 Exceed
Obove my muffler there was a heat shroud that had gotten loose so I messed with it and it went away for a long time. It came back and now I don't have a shroud anymore, I'm planning on moving my exhaust to a side exit.
- tonydca
Sometimes the heat shrouds get bits of gravel in them. If not a loose hanger problem, try getting the muffler shop to blow these out with compressed air.dfnder wrote:Obove my muffler there was a heat shroud that had gotten loose so I messed with it and it went away for a long time. It came back and now I don't have a shroud anymore, I'm planning on moving my exhaust to a side exit.
