Captain Chair wobble fix pictures needed
BCDelica
Vehicle: WVO Powered Tuk Tuk
Post by BCDelica »
With the Delica wiki unavailable and the original pictures of the L300 captain chair wobble fix pictures not being available, we need someone to take new pictures when they fix there own wobble.
Original post - http://www.mdocuk.co.uk/forums/viewtopic.php?t=13710
If your kind enough to do so, please upload the pictures to Delica.ca so they stick around.
Instructions from that post;
Start by undoing the four 14mm nuts that hold the seat to the runners on the floor of the delica
then remove the seat from the delica [take great care as the seats do weight quite a lot]
next lay the seat on its back so you can acess the seat base and undo the four 12mm nuts that hold the metal base to the seat
if you now look down the side of the seat you will see two 14mm bolts that hold the seat back to the base remove these
now get some pliers and remove the R pin clip from the release linkage
and remove the R pin clip that is just below were you have taken out the last one
you can now with care pull the seat base down away from the seat
you will now see four bolt around the out side edge of the center turn plate on mine they were 5mm allen key bolts but on bruces jap copies they look like 12mm bolts
slacken off two bolts on one side but do not remove the bolts yet
remove one of the two loose bolts
then you need to lever up the plate that the bolts go through and place a washer under it in the place were you have removed the bolt
then refit the bolt lossely and remove the other bolt and repeat with the washer you can now do up the two bolts that side and repeat the process on the other side of the turn plate you can now in revese order put the seat back together and refit it to the delica
I hope that this was some help to you all?
And thanks again for all the info Bruce. - OFF COURSE!!
Thank You,
Kevin
Image Call me BCDelica-less
nxski
Re: Captain Chair wobble fix pictures needed
Post by nxski »
Damn, I just did that a week ago. It's actually quite simple, the pictures weren't necessary although would have been helpful. What I found was that there was already a washer put there (possibly to fix the wobble at an earlier date!?) So I had to put in 2 for each bolt. Make sure you keep your eye on them and put them in the appropriate spot (It's fairly easy to see if you can visualize where the problem is coming from) It took about 10 minutes of fishing around with a coat-hanger to get one of the washers back and another 30 minutes to re-assemble the chair and find out I'd put the washers in the wrong place. :?
The gist of what I'm saying is that if you really need to do it while the Delica wiki is unavailable you can use the instructions as posted and figure it out... If someone does have pictures though, all the better! 8-)
Vehicle: -
Post by fexlboi »
nxski wrote:while the Delica wiki is unavailable
BCDelica wrote:With the Delica wiki unavailable
Are you guys talking about our wiki? https://www.socialtext.net/delica/index.cgi
Works for me and hasn't been affected by our software update. :-)
BCDelica wrote:the original pictures ... not being available
Repeat after me: http://www.delica.ca/forum/please-uploa ... -9383.html 8-)
nxski
Post by nxski »
I wasn't sure if Delica wiki was unavailable or not but the photo's don't work for me. Either way, I will repeat after you...
fexlboi wrote:please-upload-your-photos-straight-to-the-forum-9383.html
BCDelica
Post by BCDelica »
Works for me and hasn't been affected by our software update at all.
Ahh cut me some slack, I was using a likely over two year old bookmark from my laptop..... :o :-D
Ummm
BCDelica wrote:If your kind enough to do so, please upload the pictures to Delica.ca so they stick around.
:-D
Just happy to still remember exactly how darn heavy those chairs are!
Start a photo gallery in the gallery section of Delica Canada and link to your gallery from your post. Best of both worlds: Clean lines in your post and pictures that won't disappear because someone forgot to renew their account. Sounds reasonable to me ~
shealy
Vehicle: 92 Delica Exceed
Post by shealy »
I just finished this job on one of my rear captains chairs. While not a difficult job, it is quite finicky and was fairly frustrating (took me a couple hours to figure it out). Mostly because once I put the chair back, it's still wobbly. Maybe even worse than before.....sigh.
BCDelica
Post by BCDelica »
Photos really are an asset with this mod, and if I remember correctly the placement and size of the washers is important.
I did this fix in 2004-5, and some gents thought I'd have pictures somewhere after all this time and with moving around 3 different countries............. :-D :-D :-D Sassy
nxski wrote:Either way, I will repeat after you...
Good ol' Bruce's instructions. Uploaded his pics as attachments so they stay.
Mystery Machine wrote:WARNING:
This mod is VERY fiddly and should not be attempted unless you are CERTAIN you can do it! Read through the guide carefully first to make sure there is nothing beyond your capabilities……you could well end up with a messed up captains chair!  :(
I do not accept any responsibility for any chairs that get messed up doing this – I am simply relaying my experience of doing a modification that I’ve always felt the Delica needs! :D
This job rates VERY highly on the Mystery Machine Profanity Scale!
To do the job you will need the following:
Endless amounts of patience
Lots of time to cool down between frustration bouts!
A VERY large swear box!
A good range of tools including:
         Screwdrivers
         Socket Set
         Spanners
         Angle Grinder
         Workbench/clamp/vice
         Files
A clean place to lay the seat while working on it – I laid out a picnic rug!
A willing volunteer to help with some parts (but I had to struggle on my own!! :evil: )
First things first – if you are attempting the seat wobble cure – Mark’s instructions are excellent and this procedure can be carried out at pretty much anytime during the 90 degree mod.
Use Mark’s instructions HERE to remove the seat and separate the base – although I found that removing the plastic trim around the seat base made separating the parts even easier:
Remove this screw (RED) and push the seatbelt buckle through into the seat base.
Undo the two trim screws at the front (RED) and remove the trim (already removed in the photo)
Do the same for the side (RED) and the back – not shown, but you get the idea!  :wink:
Now use Marks instructions to get the seat base seperated from the main body of the chair.......
Now loosen the four bolts (RED) with a 12mm spanner/socket. DO NOT REMOVE THEM – just undo them most of the way. (Now would be a good time to do the seat wobble mod.) Unclip the spring from its mounting clip (GREEN CIRCLE)
With the spring unclipped, slide the bar (BLUE) to the left to release the arm from its locator (RED)
Working underneath the seat base, use an 8mm socket/spanner to undo the nut (RED) and remove the arm and spring. Be careful when doing this because the whole assembly is under a lot of tension from the spring! Make sure you don’t let any parts ping off!
Once the arm and spring are removed you will be left with a bar coming down through the middle of the seat base (RED) where the nut and washer were just attached (GREEN)
Back up on deck – undo and remove the two bolts (RED) with a 12mm socket/spanner. The area circled in YELLOW is the other end of the bar highlighted in RED in the previous photo. This is where you’ll be working next…..
Using a pair of long nosed pliers, or a pair of small screwdrivers, lever of the small retaining washer (BLUE) from the end of the bar (RED) BE CAREFUL not to let the washer ping off into oblivion – you don’t want it ending up with all those lost odd socks etc….never to be found!! :shock:  :shock:
With the retaining washer (RED) removed from the bar (BLUE) now slide the main bar (YELLOW) to release the arm from its locator.
Using a 12mm spanner/socket, undo and remove the four bolts (GREEN) from the disc. You’ve probably noticed that the bottom left bolt is an allen key type – I can only assume this has been changed at some point for some obscure and unknown reason! You will probably have four bolts like the one top left??
Carefully lever out the nylon washer from the disc (RED)
Pulling the big bracket to one side (GREEN) slide out the disc from the seat base (RED) This is where you need to make sure the bolts on the clamps (the ones with the red paint on in the photo) are very loose!
This mess is what I can only assume to be the remains of a nylon washer/bearing/support for the seat disc. Obviously it has worn away – probably causing the seat wobble!  :?  I decided to leave the mess because the nylon acts as a good lubrication for the disc. It might help and it certainly won’t do any harm to leave it! :wink:
The disc removed – showing the slots for the chair positions: RED for the forward an rear facing positions and the GREEN for the 30 degree positions.
The YELLOW circles show where the 90 degree slots will need to go.
Note the centre lines I’ve marked through the disc….accuracy is all important here! The slots need to be 15mm wide (RED) (7.5mm either side of the centre line) and 10mm deep from the edge of the disc (BLUE)
Note that I also marked the bottom left hole with an arrow – this is to make sure I put the disc back in the correct way around!
The slot cut out –I used an angle grinder, but a hacksaw ‘might’ do – just bear in mind that it is VERY thick metal and will take a lot of work!
Make sure you stay within your markings – it’s easier to remove material…..you can’t replace it (without a LOT of work and a welder!! :? ) I’ve still got a bit to remove on the left – and used a file to do this final bit.
If you do use an angle grinder – maybe best to cover up! It was a HOT day and I had no footwear or top on! OUCH!! : shock:  I did have goggles on though! :wink:
The slots now cut (RED) and finished off. Double and triple check your measurements before you refit the disc – once it’s in, it’s going to be a pain to remove again just because you didn’t get it right!
Replace the disc and refit and tighten all the bolts (RED) with a 12mm socket/spanner.
Relocate the arm (GREEN)
Make sure all nylon bearings/washers are properly located in their respective positions (BLUE) – ESPECIALLY the one you removed from the centre of the disc!
Now for the fun/tricky bit!! :?
The next few photo’s caused me the most frustration – but having found a solution after LOTS of cussing and sore knuckles….I might have saved you some time and hassle! :wink:
Place the bar (BLUE) through the spring and arm and put the 8mm nut & washer (RED) on the bottom – but only do up by a few turns for now!
You need to fit the arm/spring back so that the end of the bar passes through the disc. This was impossible to do on my own due to the pressure of the spring and I had to come up with a means of doing it after countless attempts.
The best way I found was to use cable ties to compress the spring as much as possible(RED) Wrap the tie around the spring – compress the spring as much as possible then tighten the cable tie. Compress the spring a little more, tighten the tie……do this bit by bit until the spring is compressed enough to allow AT LEAST 10mm of the bar (BLUE) to protrude unhindered. 20mm would be better if you can compress the spring that far.
From the underside of the seat base – place the bar/arm/spring assembly back in the base (RED) and ensure the wide tube passes neatly through the nylon washer in the disc.
The bar should now protrude through nylon washer in the centre of the disc. Replace the arm (RED) and push on the retaining washer (BLUE) as far is it will go.
From the underside of the seat base again – CAREFULLY cut the cable ties to allow the spring to re-tension. Push down on the arm when you do this to take up the tension, then cut the ties and release the arm slowly.
Now replace the spring on its locator (GREEN) and ensure that all the bolts (RED) are tightened.
Refit the seat parts in the reverse order using the guide that Mark produced (if you have already forgotten the sequence!!)
Put the seat back into the motor and bolt it back down – now test it out!!!! :D  :D
cont..
cont...
last of them ...
shealy
Post by shealy »
Wow, that post would have been amazing help to have read before and/or during my frustrating attempt at the wobble fix! Guess I should do a bit more research in the future before attempting these mods and repairs. Interestingly, in the post it mentions something about having one allen key bolt on the spinning disc of the seat (of the 4 bolts) and mine had one as well....odd. Anyways, don't suppose anyone has any further specifics or tips on the wobble fix in terms of what size washers, how exactly to set them etc? Thanks guys, these forums are extremely helpful to a new(ish) Deli owner!
nvanadm
Post by nvanadm »
Here are some pictures for just the Wobble Fix for anyone doing it in the future.
Remove these 4 nuts.
Remove this nut. Careful, they spring is springy.
Remove the plastic pieces around the base (shown above in previous post).
Remove these 4 nuts and 2 pins.
Put the arms down on the chair because when you remove the next two bolts, the chair is going to want to collapse flat. This will help.
Remove these two bolts.
Now separate the base from the chair.
