Oil leak
SunshineCoastMark
- Vehicle: 1990 L300 Delica
Oil leak
I have a nasty oil leak comming from or around the turbo , on my L300 ,is this common , any tips on how to fix it ,or how much it would cost to get it done, thanks .
- konadog
- Vehicle: 1992 GLX L-300
Re: Oil leak
Pretty common spot I think - I had a leak there too. Switched from 5 - 40 synthetic oil back to 15 - 40 mineral and the leak stopped....
- TardisDeli
Re: Oil leak
As Konadog says, common on L300. If the leak is AFTER the turbo, and merely making a bit of a mess on the undercarriage, that's common. If it drips down to the ground, or swooshes onto the sides of van while driving, then it is much too much. If leak is before the turbo, it will very much affect your driving, as the air vs fuel ratio is more affected. If turbo totally dies, you will still be able to drive, just goes slow on the uphills etc as not getting enough air into the air vs fuel mixture. You can get the turbo rebuilt, costly, but performance is super responsive. If you're thinking of getting the turbo rebuilt sooner or later, then do it sooner and enjoy passing other delicas on the highway. Cheers, Christine.
Christine
- Vehicle: -
Re: Oil leak
Contact CVI (604 247-0500) in Richmond. They already fixed tones of these turbo leaking problems.SunshineCoastMark wrote:any tips on how to fix it ,or how much it would cost to get it done, thanks .
