does anyone know where i can get my Van inspected (out of province inspection) by someone who knows how to fix the problems involved with a Delika L300 to get it passed. i just dropped 200$ at a shop that tore it apart and had no sympathy for the old girl. its in great shape, its safe and drives like a dream but needs educated eyes. Calgary area? im in Banff now. HELP
andrew...
Alberta Delika inspection. HELP
everythingells
- Vehicle: Mitsubishi Delica L300
- thedjjack
- Vehicle: 1989 L300 HITOP!!
Re: Alberta Delika inspection. HELP
I offer no help for Alberta
but what did they fail it on?
- Jungle Jon
- Vehicle: Toyota Tacoma
Hi Andrew,
Here's a couple of relevant threads that should help, I found these by putting 'inspection' and 'Calgary' into the search tool.
http://www.delica.ca/forum/new-member-f ... on+Calgary
http://www.delica.ca/forum/best-place-f ... on+Calgary
Stay away from Canadian Tire!
Hope that helps!
Hope that helps!
everythingells
they Failed it because one of the front drive shaft u-joints seized, the rear transmission mounts have splits in the bushings, and the bushings on the front stabilizer links are cracked and on is split. the tires were a bit rough but thats easy to replace and the stabilizer bushing are an easy job and part to find so its just the Transmission mounts and front drive shaft. ???? what do you think?
everythingells
Thanks a bunch for your help!!! im really trying to not spend to much time repairing so i wanted to find an easy pass and then get things fixed when money and time were more available. right now i want to drive and camp!!!! but i got lots from those links. so thank you!
Jungle Jon wrote:Hi Andrew,
Hope that helps!
