Fuel filter problem solved!!
- dennis_lambert
I changed my fuel filter out on my wifes Delica tonight for the first time,And now it runs for a bit and then eventually stalls.Has done it about 4 times until I killed the Battery.Thinking maybe an air lock....
Has anyone had this issue?
Where is a good spot to purge the system of air?
Thanks for your help.
Last edited by dennis_lambert on Fri May 28, 2010 6:51 pm, edited 1 time in total.
fozzie
- Vehicle: '90 delica exceed
Re: Fuel filter change gone wrong!!
Open the air valve and give it a couple of pumps until bubbles come out the valve.Then close the valve with the pump depressed. That will get any air out. Hope it helps.
There's the white plastic valve on the bottom, and a spongy pushbutton on the top.fozzie wrote:Open the air valve and give it a couple of pumps until bubbles come out the valve.Then close the valve with the pump depressed. That will get any air out. Hope it helps.
- snelson
- Vehicle: 92 Delica Exceed
Just to clarify, the white plastic valve is not for purging air, but to release any water in the filter.
The purge 'valve' is a nut/bolt about a 8 or 10 mm up top near the plunger.
"air up, water down"
- White Mule
- Vehicle: 1991 Delica L300
The bleeding routine can be difficult with the new filter bolted in place.
The pumping and nut tightening can be done prior to final placement of new filter.
Try not to get too much fuel splatter, in fact stuff/ pack several rags in the area.
(Sounds crazy), but double check your inlet and outlet hoses.
Thanks,
White Mule
White Mule
I replace mine outside of the Delica and fill it up with fresh diesel prior to priming and installing.
Less air and makes it easier.
- after oil
ive started my delica without bleeding the air several times. ill bet theres not an air lock, but an air leak? perhaps the filter is threaded wrong, or not enough...
- dennis_lambert
Thanks for everyones help.When I get off work I will try to bleed it out.I did not realize the pump had a bleed port on top.I connected the filter and just pushed the pump up and down until it got difficult to pump.
So to clarify I need to open the bleed port on top of filter Assy and pump air out....
Thanks alot everyone.
Dennis.
Dennis.
You got it. I had momentary cranial flatuence and it all came out wrong...dennis_lambert wrote:Thanks for everyones help.When I get off work I will try to bleed it out.I did not realize the pump had a bleed port on top.I connected the filter and just pushed the pump up and down until it got difficult to pump.
Dennis.
- dennis_lambert
Re: Fuel filter problem solved!!
Thanks everyone for all the great info!
Problem solved
It was I think a combination of air entering in through the Assy (Not quite tight enough) and I needed to crack the 10 mm bolt on top and pump the air out.Runs great again.
Cheers!
Dennis
Problem solved
Cheers!
Dennis
- after oil
we were all right! yay team!
As the Broken Lizard crew would shout: "Go Team Ramrod!"
No?
No?
Paule
- Vehicle: 1997 L300 Active World
Farva! Grab a mop, you're my cleaning lady now!mararmeisto wrote:As the Broken Lizard crew would shout: "Go Team Ramrod!"![]()
