Trying to find front brake pads, rotors, calipers!
Squamishtoaster
Vehicle: '92 Mitsubishi Delica
Post by Squamishtoaster »
Hello. I have been searching the L300 technical forum on this subject and found alot of useful info. I need to get new front brake pads, rotors and calipers for my '92 delica P35 L300 starwagon. I am under the impression that I can go to lordco and order these parts for an '88 montero and they will work on my deli. Does anyone know if this is true. If not I will go buy them from Japanoid but I live in squamish and it would be nice to save myself a trip to New West. Any info that you could provide would be greatly appreciated!!
Thanks for your help!
PS I also found these part numbers. Does anyone know if these are correct!
Arnley Rotors: 083-2471
Pads: PGD-530c (raybestos ceramic)
Arnley Calipers: 077-10595
077-10605
Vehicle: -
Re: Trying to find front brake pads, rotors, calipers!
Post by fexlboi »
Squamishtoaster wrote:I am under the impression that I can go to lordco and order these parts for an '88 montero and they will work on my deli. Does anyone know if this is true.
True.
Save $ and don't go to Japanoid.
Squamishtoaster
Great, Thanks very much for your quick response it is greatly appreciated!!
RichD
Post by RichD »
Brakes and rotors are standard consumables; don't need to buy special bits from importers.
Lordco has a Delica L300 parts list. If your particular Lordco does not, have them call Kingsway (Burnaby, BC) Lordco and get faxed a copy.
I bought new Ceramic brake pads and installed them last week. They also carry the rotors (and had stock). Raybestos PGD349C confirmed installed perfect match. Also they have a $10 cash back right now on those.
See also: http://www.socialtext.net/delica/index.cgi?part_numbers
Richard Dagenais
Squamishtoaster
Great Thanx again this is very helpful!!
Golf Cart
Vehicle: 1992 Exceed
Post by Golf Cart »
Squamishtoaster wrote:Hello. I have been searching the L300 technical forum on this subject and found alot of useful info. I need to get new front brake pads, rotors and calipers for my '92 delica P35 L300 starwagon. I am under the impression that I can go to lordco and order these parts for an '88 montero and they will work on my deli. Does anyone know if this is true. If not I will go buy them from Japanoid but I live in squamish and it would be nice to save myself a trip to New West. Any info that you could provide would be greatly appreciated!!
077-10605
Hey Toaster,
The numbers above are for the upgrade - the twin piston caliper. You will need to trim a bit of the back plate on the van so the calipers will fit.
RichD
Post by RichD »
Yer gonna laugh, but here is an iphone snapshot of the L300 list from Lordco's internal cheat sheet.
Note the rotors 101-3280
Richard Dagenais
Squamishtoaster
That parts list is awesome!!! Thanks for that.
Rich, that's even better than secret agent micro film! Which store did you get that from?
RichD
Post by RichD »
Kingsway
Richard Dagenais
fishslapper
Vehicle: 1994 lwb l400
Post by fishslapper »
That is sweet !! no more trying to figure out what the heck to ask for !
I am going to use that info right now..
rad cap
rotors
pads
and shocks !!
This needs to become a sticky !!
The Mighty Boosh !!
RichD
Post by RichD »
I tried Golf Cart's truck after the "-ero" upgrade and I have to say that the difference is tremendous.
I got the following quote from Lordco:
Arnley Rotors:
083-2471 - 91.69/each
Arnley Calipers:
077-1059S (left) - 66.09 (core 60$)
077-1060S (right) - 66.09 (core 60$)
Pads:
PGD-530c (ceramic) - 83.79/set
My friends at DB Aldous do much better on the brake pads, and highly recommended kevlar/metallic over ceramic for this application:
MD530 (kevlar, metallic) 36.54/set
Richard Dagenais
Golf Cart
Post by Golf Cart »
And this afternoon RichD, Lazybrownfart & myself installed all the new hardware. I must say Rich was beaming that he could hit the brakes and almost launch the rear wheels off the ground in a panic breaking test.
Now a quick changeover to braided steel brake lines, another bleed and we;re done like dinner.
Glad he's happy.
RichD
Post by RichD »
Golf Cart wrote:And this afternoon RichD, Lazybrownfart & myself installed all the new hardware. I must say Rich was beaming that he could hit the brakes and almost launch the rear wheels off the ground in a panic breaking test.
Yes, the truck stops now, and with confidence. :-D Best upgrade to the van so far. IMO everyone should be encouraged to replace the stock calipers & rotors. I really appreciate your help, guys, and look forward to treating you to dinner.
This of course has once again highlighted the need to fix my torsion bars, and soon!
Pretty sure I need to open it back up as I heard some noise from the left wheel that I don't much like. I am already sourcing a set of SKF-BR50 wheel bearings, and the hex-keyed fasteners for the hubs too since mine were a little thrashed coming off.
I'll probably wait until I lift the truck to do steel braided hoses.
Richard Dagenais
Vehicle: -
Post by fexlboi »
RichD wrote:hex-keyed fasteners for the hubs too since mine were a little thrashed coming off.
You probably want to check out WestCoast Fastners in Burnaby.
They have the biggest selection of fine threaded metric high grade bolts. If you find suitable bolts, please get a set for both sides for me too (+ a few spares)
Probably the main problems is to fit a socket in the tight space.
