Looking for a part number for the center two front sway bar bushings.
These bushings are shaped like a D and wrap the sway bar itself.
was able to find part numbers for the other 8 bushings
you need 2 packs as each contains 4 bushings
9.8101G (black) or 9.8101R (red) both work,
Here's a pic of some energy suspension bushings which i thought would fit.
thx colby
Front Sway Bar Bushings
cobsweb
- Vehicle: 92 Exceed
- rsz_img_1025.jpg (74.32 KiB) Viewed 2170 times
cobsweb
Re: Front Sway Bar Bushings
John @ Rocky Mountain Imports stocks all Mitsubishi bushings for the front sway bar.
The "D" bushings weren't listed on the website but he had them.
colby
colby
- snelson
- Vehicle: 92 Delica Exceed
Just for my own knowledge - aren't those technically torsion bar bushings?
Sway bar bushings are the little loonie sized donut ones...no?
EDIT - ahhhh ok - I just realized where these bushings go and you're right they do in fact go on the sway bar....I didn't change these when I did the other ones a couple years back, so they didn't look familiar to me
