I'll be getting one of these, just spoke to them and they put the discount back on their site...
http://www.rovingrecovery.com/madman.htm
David
Good deal on multi-gauges system
- delicat
- after oil
- delicat
Re: Good deal on multi-gauges system
Ari, are you thinking what I'm thinking... use the oil temp and coolant temp sensors to monitor your wvo???
I'm pretty sure the sale ends at midnight.
- after oil
mainly i was just thinking "cool"delicat wrote:Ari, are you thinking what I'm thinking... use the oil temp and coolant temp sensors to monitor your wvo???
but i definitely thought about how it would enhance the wvo experience. i trust the stock temp sensor to do its thing...
- Erebus
- Vehicle: 1992 Super Exceed
Sweet. That is one very nice unit. Not much more expensive than an EGT by itself, saves a lot of dash space.
The sale price is still showing right now (4 Jan).
This should be posted cross-posted to the Mods and/or General forums!
"I could be just around the corner from heaven, or a mile from hell." -- Jackson Browne, "The road and the sky".- danfromvan
- Vehicle: '93 p25w Jasper auto
Can we assume it will fit in the normal Delica dash pod to replace the inclinometer or the altimeter?
- Erebus
I'm thinking the square one should. The install template shows a 57.9 mm hole with the crews being on a 67mm diameter circle.
That's pretty close to the 2.25 or 2.5" holes standard North American gauges use. The EMS-1 is a much larger rectangle, but would probably fit quite nicely above the speedo/tach cluster.
