I read somewhere on the Aus site that the factory GPS antenna (for newer vans than mine) is in the binnacle. If that's so, shouldn't I be able to hide my GPS antenna in there too? Oh, btw, does anyone know what that gray thing is with the arrow on it that sits under the compass and do I actually need it? (2nd photo.)
It'll be tight but I think I could fit my antenna in the binnacle somewhere, as long as it's going to function properly all the hassle. Also, there's a small flexible metal plate which is supposed to be used as a base for the magnetic antenna "node". There's what I'm wondering about:
1) Can I dispense with that little plate if I mount directly to metal or is that little thng somehow indispensable?:?
2) Another thing is, I intend to remove the leveling ball in left of binnacle and mount my pyrometer's digital gauge there instead. Would that gauge being in close proximity to antenna node interfere with its functioning?
The binnacle would be my first choice but another alternative might be to mount inside one of the acrylic "crystal roof" sections...
3) Does the GPS antenna node need to be facing "up" or would it also work upside down, stuck to a crystal roof panel?
Thanks!
