I'm posting this on the off chance someone else has had the same problem, since the rains have hit i've recently noticed the drivers side floor is soaked... It happens whenever it rains, Driving or parked, theres NO leak from the door seals or the windscreen infact nothing gets wet above the floor, there are no holes in the floor pan and its not rusty, i've tried pouring water all over with the carpet up (headlights, door seals etc) and I see nothing, yet after its rained the carpets soaked...
Does anyone know of a good trick to find leaks? or better still had exactly the same one and fixed it :)
thanks for any suggestions..
kinl
Mistery Leak Drivers side floor... (rain type leak)
- Kinl
- Vehicle: Black Delica GLX L300
- snelson
- Vehicle: 92 Delica Exceed
- BCDelica
Re: Mistery Leak Drivers side floor... (rain type leak)
Oh, always thought it was - wet floor site:delica.ca, which is my prefered method to forum search buttons.
Whoops, double post.
Call me BCDelica-less- nvanadm
I think most of us have been there... It's been a hot topic on this forum MANY times. There are numerous threads on this site regarding this topic.Kinl wrote:I'm posting this on the off chance someone else has had the same problem kinl
Here are a few to get you started...but the search feature does wonders.
http://www.delica.ca/forum/my-feet-are- ... tml#p15049
http://www.delica.ca/forum/wet-floors-anybody-58.html
Good Luck!
Meanman
I've also found if you lift the carpet and look forwar towards where the headlight bucket would be there is a seam at the bottom that will leak as well.
- Kinl
Thanks for those..
p.s. What is this "search" feature you speak of, sounds like magic to me, I don't trust it
- nvanadm
Same here. Brought it to Mardy (MardyDelica)...paid $50 and that was the end of it.Green1 wrote:(mine turned out to be the seal along the top of the windshield)
I grabbed a tube of silicone sealant for $3 and that was the end of it...nvanadm wrote:Same here. Brought it to Mardy (MardyDelica)...paid $50 and that was the end of it.Green1 wrote:(mine turned out to be the seal along the top of the windshield)
