We are introducing a NEW service package that will solve those oil leaks on the deli/pajero Turbo and enhance the performance as well.
The service package includes the following:
*Turbocharger overhaul with Sonic Cleaning.
*Replace Intake & Exhaust manifold gasket with Mitsubishi OEM metal gasket
*Cleaning of the EGR Valve
*Complete cleaning of Intake and Exhaust manifold components
Service Time - One Day
Cost - $685.00 plus Tax
Introducing !! CVI's "leaky" Turbo FIX !
- CVI
- Member's Photo Album: http://cviauto.com
- Vehicle: 1994 Delica Space Gear Royal Exceed
- Turbocharger BEFORE !
- IMG_0457.JPG (50.56 KiB) Viewed 4451 times
- Turbocharger components after "SONIC" Cleaning.
- IMG_0458.JPG (30.11 KiB) Viewed 4444 times
- Instake and Exhaust manifold & components after cleaning.
- IMG_0459.JPG (39.06 KiB) Viewed 4448 times
- Turbocharger AFTER !
- IMG_0460.JPG (27.39 KiB) Viewed 4450 times
- fishslapper
- Vehicle: 1994 lwb l400
Re: Introducing !! CVI's "leaky" Turbo FIX !
This service does wonders !! i thought my turbo spooled up nice........but after hearing and seeing one on one of their customers delicas ,yesterday all i can say is wow !! I have to get this done !!
this thing sounded like a space ship with a really sweet smooth spool up !! Plus it would be nice to not have oil in my driveway. I thought that i was done with vehicles that maked their spot when i stopped driving my vw bus !!
cheers
isaac
cheers
isaac
The Mighty Boosh !!
- snelson
- Vehicle: 92 Delica Exceed
Boy you left-coasters are sure fortunate having CVI - planning on a trip out this summer to have them spruce up the Deli. This turbo fix is now on the list along with the famous tune-up and once over.
- delicat
Just curious,
When you say "Turbocharger overhaul", do you mean you're replacing worn out parts like bearings and seals or just cleaning the turbo? 'Cause if you're doing a full overhaul that's a real good price and I'll have to start saving money!
- loki
delicat wrote:Just curious,
I would imagine some stuff gets replaced to be able to stop the oil leak?
- fishslapper
I am not An employee of cvi but to answer delicat....
I believe butch said to me that this includes all new seals and bearing And ultrasonic cleaning etc...etc.. Not just worn parts !! I know, it does seem like a great deal with all the parts al labour !!
I guess when you have a guy like edwin moving so fast he can do this in 20 min's ,you can still make money !! lol's
The Mighty Boosh !!
- CVI
Hi De i'ca...(",)
We do a complete teardown of the turbo, check for bearing condition and replace it if necessary. Carbon seals and housing where it seats are all sonically cleaned together with the master assembly housing, turbine and compressor wheel. All seals are replaced. As this components spin at around 85,000rpm at full load, it is a very delicate engineering piece of art.
As we have encountered a number of manifold gasket failures in the past, we have taken the necessary step to take care of this problem by replacing the old gasket to the new metal gasket from Mitsubishi OEM Parts. And while we're at it, we sonically clean the EGR valve too as they have been known to fail as well. These takes care of the Preventive Maintenance work needed on this side of the engine to perform at its best without worrying about this things failing in the future. Peace of mind and knowing that all is well on the power plant makes driving our delicas more enjoyable.
- delicat
lol! I can almost hear Maceio!mitsubc wrote:Hi De i'ca...(",)
That's really good to know everything is taken care of.
If your turbo is leaking than it's pretty obvious it needs attention but doesn't mean it's shut. They can still leak and work great but I guess it's just a matter of time. On some like mine the turbo doesn't leak at all but I still checked it out recently to make sure the bearings were still decent. I took the front rubber hose out of the way and grabbed the nose of the turbine. On a good turbo there should be hardly any noticeable play if trying to move side to side. I had more play than expected.
But any better way to tell if your turbo could use a face lift?
