Warning! ProComp shocks problem
Profister
Post by Profister »
Hi All,
While installing manual hubs I discovered something odd on the left side. Now I am wondering who to blame: the product quality, the installer or just my bad luck. Also I would like to know if anything can be done to fix the bushing or the shock needs to be replaced.
Thank you in advance.
Sergiy.
Vehicle: -
Re: ProComp shocks concern
Post by fexlboi »
Sergiy,
The rubber bushings get worn out pretty quick. That's a known issue. You should change them to polyurethane bushings. Just a few bugs, but will improve the lifetime of your shocks a lot.
Profister
Post by Profister »
Thanks Felix, and where should I go for polyurethane bushings?
Vehicle: -
Post by fexlboi »
Profister wrote:Thanks Felix, and where should I go for polyurethane bushings?
I got mine at North Shore Offroad, but I'm pretty sure other shop will have them too.
loki
Post by loki »
what is the moister around the connection? did you spray it with something or is the shock leaking?
Profister
Post by Profister »
It was snow originally.
Golf Cart
Vehicle: 1992 Exceed
Post by Golf Cart »
Profister,
How long have you had those shocks installed ? I remember when I did mine, I had a bitch of a time putting the bar through the bushing. I had to gease the heck out of it and had to press the bushing back in using a vise.
fexlboi wrote:Sergiy,
x2 the poly bushings are much better
MardyDelica
Post by MardyDelica »
hi sergie, i can get you some polyurethane.
call me anytime
cheers
RaddCruisers
Post by RaddCruisers »
Wrong type of bushings for that type of mount. You need one piece bushings, not the 2 piece units. You probably did not get the right kit for the application -
~John
E4 Auto Repair Ltd.
& Radd Cruisers 4WD
Duncan, BC
250 746 8977
Profister
Post by Profister »
That was my guess. I was wondering how the hell two pieces could stay in place without anything holding them from the sides!
Golf Cart - I bought these shocks from Mardy and installed by RJD in June last year.
Golf Cart
Post by Golf Cart »
Thats odd. I bought mine in September from Mardy and they were one piece bushing that were an hour glass shape. From your pic, it looked like the bushing split in half
Profister
Post by Profister »
I am not sure if it was one piece and it just torn apart or there were two pieces originally but it needs to be replaced for sure. Looking at the mounting I do not like it at all to be honest.
Great thanks everybody for your help.
Sergiy.
Vehicle: -
Post by fexlboi »
Golf Cart wrote:...it looked like the bushing split in half
I think so too.
MardyDelica
Hi, that was the right 1pcs. its only have on pcs. not 2
its just the way they put is not much stronger. need the urethane one they say some shock they put urethane.
i already inform pro comp about this just let me know when you have time to come buy & will give you one with urethane robber.
cheers;
