Tow Hitch Receiver
Raule Duke
Vehicle: 92 Pajero SWB
Tow Hitch Receiver
Post by Raule Duke »
I've got a 92 SWB and would like to tow my utility trailer and was wondering what people hve done for a hitch receiver
i've got a little plate with 4 bolts and a tow point in the bumper now...
thinking about fabbing a plate with reciever but am worried about the bolts shearing....
any ideas?? photos are great too!! 8-)
cheers
cj
"There's a uh, big machine in the sky, some kind of, I dunno, electric snake, coming straight at us!"
Re: Tow Hitch Receiver
If you're on the mainland, E&H Hitch (604.433.4611) does a bang-up job of fitting a custom hitch receiver to the Delicas. When I got mine earlier this year, Rick indicated that they'd fitted well over 50 onto Delicas. I suspect the underside of the Pajero is little different than our vans.
PHIL
Vehicle: 97 PajEvo, 92 Strada, 03 Montero
Post by PHIL »
There are lots of commercially avail hitches out there. Well, maybe not lots, but a few. I currently have a 1 1/4 receiver that bolts onto the rear crossmember's four bolt plate. There is also a 2" version of this hitch out there. For my new truck (hopefully coming on the truck this evening!) I got a big-ass 2" receiver that bolts to the frame AND the four bolts in the center.
There are versions made by Reese, Curt Manuf'g, and Valley industries, to name a few. Try hitchweb dot com...
1997 Pajero Evolution no.581
1992 Strada 4-door pickup
2003 Montero XLS
Raule Duke
ok great thanks alot, if i'm looking for the one that just bolts up to that existing mount, what about this;
http://www.youtube.com/watch?v=oJQo9ro9 ... re=related
hhaha :shock:
i hope it's strong
PHIL
Post by PHIL »
Raule Duke wrote:ok great thanks alot, if i'm looking for the one that just bolts up to that existing mount, what about this;
hhaha :shock:
i hope it's strong
I'm pretty sure that was strap failure. I've towed for two and a half years with the center bolted receiver on a genII. No problems. Also towed with a genI hitch attached the same way. Worked fine.
NATO style pintle hitch is also a direct bolt up to that plate, if you can use that style with what you're towing...
2003 Montero XLS
PHIL
Post by PHIL »
Here are the class II's:
http://www.hitch-web.com/vhitch.asp?CLI ... 512&BPID=6
Here's the class III
My new one doesn't seem to be listed. I'll check around...
2003 Montero XLS
Raule Duke
well i ended up fabing up a cheap alternative to ordering a tow hitch...
i took one of the "flat bar" style ball mounts (i think it's called class 1) and cut it a bit short and then welded it to the factory tow point on the pajero
i already had both the bar and ball but i have seen similar stuff at Princess Auto for about $8 for a 2inch ball and $22 for the flat bar ball mount.
the factory tow point made a lot of "Real estate" to weld around if you could imagine having the flat bar butted against the flat piece that the four bolts holes are in and the top of the bar against the tow hoop.... so i could weld around the inside and outside of the hoop
again i will post pictures as soon as i get a new digital camera!!
anyway i will only be hauling a small 4x8ft utility trailer so this should be more then strong enough
bae146
Post by bae146 »
hhaha :shock:
i hope it's strong
Ha Ha, that strap was attached to the factory tow point. The only good use for that attach point is for tying it down while it is on the boat coming from Japan. Look closely and you will see the ford windstar roof rack on the top of that one..
Raule Duke
i borrowed the inlaws camera to post the pics of the trailer mount.... not the prettiest weld no doubt so just ignore it hahaha
but works great.... if you've got the parts and wanted me to do some welding for you i'd be happy to take beer in exchange!!
cheers
cj
BHA
Vehicle: Pajero 2.5TD
Post by BHA »
Hey
I got a 2 inch receiver added to my 92 SWB last week - bolted straight onto the existing plate (just removed the old circular one) and had it wired for power at the same time. The power point was fixed into the bumper - just needed a small hole drilled but looks awesome
Burnaby Hitch did the job for me...very pleased with it
Brian
supplespence
Vehicle: 1991 mitsu pajero exceed
Post by supplespence »
go to princess auto, they have the four bolt hitch there. its an 8 ton, pintle/ball combo and its the cheapest you can find anywhere... including the states.
Return to “Pajero”
