how do you tell if the delica has LSD
madmazda
- Vehicle: 1994 l400
just a quick note on if there is a specific # code on the delica that lets you know if it has a lsd or not???? I saw on a pic, on the diff cover that the oil bung had stamped on it to use propper oil for the LSD.
Meanman
Re: how do you tell if the delica has LSD
As with any LSD or locker....if unsure jack rear of vehicle up so that both wheels are off of the ground. Spin one wheel by hand...if the wheel on the other side spins IN THE SAME direction you have LSD if they spin in opposite directions you have an open diff.
madmazda
well I don't have one yet looking hard on this site for a good price and quality one just hoped someone would know of a # code on the VIN or someplace else...on your note...when I do get mine I'll be sure to check...thanks for the advise...:)
- JMK
- Vehicle: 92 Chamonix
How did that work model wise? For example it was my understanding that all Chamonix had LSD, and that some other models also had it. Did some Super Exceeds have it and some not? Wasn't there a post here a long time ago that outlined all the features of the various models?
I never knew about the 'heavier paint' on the Chamonix until I read that here today, and I have a Chamonix.
- The Pinkfingers
- Vehicle: '94 Exceed
If it starts singing about tangerine trees and marmalade skies, and girls with kaleidoscope eyes...madmazda wrote:just a quick note on if there is a specific # code on the delica that lets you know if it has a lsd or not????
madmazda
does this mean that it uses LSD or has it...lol.... that comment just made my day....thanks...made up for my chilly mtn bike ride i had today in our 6 inch snow fall...:D)
madmazda
I've seen listing here where exceeds have it super exceeds have it plus the jasper and chamonix as well....
JMK wrote:How did that work model wise? For example it was my understanding that all Chamonix had LSD, and that some other models also had it. Did some Super Exceeds have it and some not? Wasn't there a post here a long time ago that outlined all the features of the various models?
it is an OPTION on the exceeds and super exceeds, I believe it is standard on the chamonix, and I have no idea on the jasper. (jasper seems to be chamonix "lite")I've seen listing here where exceeds have it super exceeds have it plus the jasper and chamonix as well....
Jonny5ive
- Vehicle: 92 Super Exceed
and they are amazed at how well designed they are... and get stuck in an existential loop...madmazda wrote:
Standard on Chamonix/Jasper.
Optional on Exceed/S Exceed
Jack up the rear axle and spin one wheel. The other side should spin in the same direction = LSD. If not = open differential.
Red/Orangish sticker 1" x 2" with black Japanese writing on the bottom/driver's side door jam.
madmazda
thanks so much.....I don't have a delica yet but will be getting one within a month or so.....just want as much info as possible so I get what i want...:)
also what are the lsd like on dry pavement????? around corners...etc...
shinta
- Vehicle: Mitsubishi Delica Starwagon
hi jfarsang, i just would like to make sure as to what diff i have. are you specifically referring to the said sticker?jfarsang wrote:Standard on Chamonix/Jasper.
if yes, it means i have ls(rear), right?- jessef
That's the right decal for a limited slip differential.
Also, anyone who does have a limited slip rear differential, please do NOT put regular 80w90 in there !!!!!!!!!
You have to put Limited Slip gear oil in there otherwise you can cause some serious damage.
