When I started driving it I was not happy with the poor power and clouds of black smoke. The van has 128,000 kms on it and had the timing belt done about 10,000 km ago. I have been hearing good things about CVI and the Delica tune up so decided to make a day of it and drive down from Kelowna. The trip down was slow, down to 50 km per hour on the hills in second gear. On the flat it wouldn't go past 100.
I hung around and watched as they did the work. They cleaned the injectors, adjusted valve lash and pump timing, put the throttle lever back to the right position, checked the timing belts etc. They did a very thorough job and gave me a lot of maintenance tips too. I was surprised how badly the injectors were fouled up, squirting rather than spraying. Something that needs be be done every 100,000 km I'd say. There was a lot of carbon built up in the system.
When we took it for a test drive afterwards I couldn't believe the difference in performance. It wanted to spin the tires. Where as it had been so sluggish starting off it now just takes off from a stop. I am very pleased with the results.
Butch even helped me get back to Hwy 1 as the route I used to come in was all under construction.
The drive home was amazing, I was cruising effortlessly at 120k, on the smaller hills it would keep right up, steeper hills at 100k. I took the Coquehalla both ways. On the steepest grade before the toll booths going back I was down to 70k in second, temp gauge rose to just above center. That is a very steep grade, 8% I'm sure and very high altitude. You feel that in any vehicle and often see overheated vehicles pulled over on that stretch. I wanted to give it a good work out and I sure did, all carbon is out of the system for sure now. I got home in very good time. What a relief.
We kind of ran out of time at the end of the afternoon at CVI and didn't finish with the full load adjustment. It was still putting out black smoke on gunning the throttle, but the power was really there. Because it had been so carboned up we weren't sure if the smoke was from fuel or just blowing carbon out of the system. It still puffs a little black when I start off so I'll adjust that full load screw back a little more yet to get rid of the smoke now, but keep the power. A bit of a trade off there, I sure like the power though and the smoke is right handy for pissing off impatient drivers behind me!!!
All in all I would recommend this tune up to anyone having issues with loss of power. You couldn't have better qualified or nicer people working on your vehicle. These guys really know what they are doing.
Bob in Kelowna
"I could be just around the corner from heaven, or a mile from hell." -- Jackson Browne, "The road and the sky".
