thermometer
alex.antonelli
- Vehicle: 1994 delica
thermometer
does anyone know if theres some kind of switch inside the thermometer on the dash to change from celcius to farenheight?
Re: thermometer
I don't know for sure, but I doubt it. These vehicles were built for a country where the metric system is used and the only measure of temperature considered is celsius.
Re: thermometer
there's only one country in the world that still uses farenheight, and these vehicles weren't built with the US market in mind...
- marsgal42
- Vehicle: The Mighty Gumdrop
Re: thermometer
...and how does somebody in the U.S. have a '94?
...laura
...laura
Re: thermometer
...cause they don't live in the US. Check their original post and you'll see they reportedly live in Japan...marsgal42 wrote:...and how does somebody in the U.S. have a '94?
...laura
...so that begs the question as to why they would want it temperature to read in F?
...unless they're a displaced American...
Antonelli doesn't sound particularly Japanese to me, but hey, I never did learn my 'ichi, ni, san'.
- loki
Re: thermometer
with the rules in the states as I understand them (doesn't mean much :)) you could have a 2008 if you wanted, you just need to get it imported and complianced by a registered importer. Now I say "just" but I'm sure it isn't cheap, but it should be possible.
alex.antonelli
Re: thermometer
actually,
antonelli is an italian name. I'm an american living in okinawa working for the government. Back in the states I had a montero and inside the accessory pod the thermometer had a switch to change from c to f how do you get that little pod off the dash?
looks kind of tricky. thanks for the help.
alex
alex
Re: thermometer
There is a snap-on facing plate at the bottom front of the pod - pop that off and you'll see a couple of screws which hold it to a plate mounted to the dash. Unscrew them, pod comes off - watch for lamp wires.alex.antonelli wrote:actually,
alex
