- deskinthewoods
- Vehicle: 1991 L300 Star Wagon named "Wilson"
Installed new headlights. The old ones were cracked and the chrome interior had dulled, which I had spray painted with chrome paint to try to fix but it was not ideal. I bought these https://www.crazythegod.com/car-brand/m ... i-lhd.html. I thought about the LED versions but I really don't like the look and they are $100 US more expensive...
Old lamp brightness:
New lamps:
So shiny
I'll aim them tonight... :)
New lamps:
So shiny
- deskinthewoods
Took some time in isolation to finish up a wooden steering wheel I started over a year ago...
I'd glued up a couple of blanks for turning For front and back halves Peeled off all the rubber and plastic from the steering wheel and painted the internal frame and routed a groove in one half for the frame to fit in
- deskinthewoods
...glued it all together with Gorilla glue
sanded it nicely
oiled it with tung oil and a coat of wax
And a prototype horn...
That has to be your best project to date!! I think even Growler would be really impressed. Great use of your spare time. What's next it seems we will have a few months left to isolate.
- deskinthewoods
Well, thank you!!!
Just maintenance stuff for a while. Installed new sway bar bushings this morning.
Last edited by deskinthewoods on Sun Apr 26, 2020 8:40 am, edited 1 time in total.
- deskinthewoods
I found some switches and an LED marker lamp in my box of odds and sods...
so, I made up a glow plug ECU bypass switch just in case the ECU dies, as they are known to do...
Tapped into the 12v relay: and used the wire I'd run to the dash for the previous parasitic draw disconnect, now redundant.
I wired in an indicator lamp and a toggle switch to turn off the circuit unless I need it, (just for fun) The lamp illuminates regardless of if the toggle is on or off, so basically it is a momentary switch that turns on a lamp!
- glow plug 3.jpg (18.71 KiB) Viewed 51495 times
- deskinthewoods
Another Covid project I've been meaning to get to: Paint!
Some rust has been appearing all over, mostly the bull bars, front bumper and wheel wells. I pulled off the parts I could and stripped and primed them.
- deskinthewoods
...masked off the van
and sprayed Raptor Bed Liner...
Its a two-part polyurethane truck-bed liner. $199CAN for 4 litres including the spray gun. Easy to apply, very little over-spray. You really have to be meticulous about your prep work. Lots of washing, degreasing and scuff-sanding.
I cleaned up the mirrors and wiper arms with a Tremclad spray-bomb while I was at it.
- deskinthewoods
I'm very happy with the result. I'm interested to see how it holds up over the next few years...
All re-assembled...
Before & After
(Replica Japanese Plate from https://www.customjapaneseplates.com/)
All re-assembled...
Before & After
- deskinthewoods
Finished up the horn button. A little Ipé, a little copper plate, a little bit of Corian counter-top material.
I lasered in the MMC logo and filled it with epoxy mixed with Ebony sawdust.
I dig your style.
- deskinthewoods
I picked up a few 10ftx2x6's last weekend and broke the altimeter/tippy-over gauge pod off it's moorings...again...
and my AC crapped out this season, compressor is seized...
so this is my new set-up:
$40. solved two problems. (I'll hang on to the pod gauges and fix them someday...)
PeterBradford
- Vehicle: Mitsubishi Lancer
Recientemente lo compré y ya lo pasé para su reparación. Y por eso estoy feliz con el auto.
Puedes hacer apuestas de rivalidad https://es.esportsbetting.pro/rivalry para los deportes electrónicos en España sin salir de casa.
Rear Bumper Rust
In July 2014 I took off a rusted rear bumper and figured to solve the problem for good buy removing the rust and painting it with POR-15 the king of rust paints! I was looking for rust in other places this fall ( I hate rust ) and found the underside looked rusted again. After taking it apart this last week I was right. It's to cold to paint outside so I've taken the pieces to be power coated. Hopefully it will last @ least 5 or 6 years. I put in a trailer hitch in 2015 and had it powder coated. It still looks good as the day I put it on. Results to follow next year.
- Rear step 2014
- 100_6755a.JPG (120.78 KiB) Viewed 25514 times
- Underside of rear step as found 2014
- 100_6757a.JPG (112.06 KiB) Viewed 25514 times
- New POR-15 August 2014
- 100_6782a.JPG (119.28 KiB) Viewed 25514 times
- 100_6784a.JPG (87.33 KiB) Viewed 25514 times
- After 6 years of POR-15
- 100_9826a.JPG (115.58 KiB) Viewed 25514 times
- 100_9827a.JPG (116.85 KiB) Viewed 25514 times
thelazygreenfox
You're awesome. Keep up the posts and your ongoing delica revival. It motivates me to do the same.
