Just a quick run-down on changing the glow plugs, since I went through a bit of a learning curve to do this (my first time).
I was having problems starting over the last week - the first time I thought just the shifter was not completely set into park, but the second time, just one glow plug "click" rather than the usual two, and totally unstartable. Battery was fine (at least lights/stereo were coming on as usual) so I assumed it was the glow plugs.
Of course, this being 1) my first diesel vehicle and 2) my precious Deli, I'm always uber-paranoid about f$%&ing something up.
First, I tested the readings on the battery and plugs with a digital voltmeter (the pos pointer of the meter on the pos terminal of the battery, the neg pointer on the glow plug tip). I didn't think until later to check the bus bar as well. The readings were all good (~12.38V) but I wanted to see if something was up anyway.
These are the tops of the glow plugs (I've already removed the wiring and plate (the bus bar) on this photo). Here's the photo with the plate and wiring: The first glow plug I pulled out. There's some oil on it which bothers me... is this normal? (it doesn't seem like it should be) Does it suggest an oil pressure problem? Here are three of the four after cleaning with a rag (I replaced the first one, then realized I should compare all four): *****
After cleaning and replacing all the plugs, I tested the connections again.
On the battery: 12.38 V
On each plug: 12.36-12.37 V
Between each plug and the bus bar, with the key turned on: 12.36V
And it fired right up on the first try. So I guess the plugs between fouled with soot/oil was the problem. If anyone wants to comment on this that would be helpful.
Wanted to add my little contribution to the Delica community for return on all of the questions I've been able to answer from reading old threads.
![Smile :-)](./images/smilies/icon_smile.gif)
- S
