L300 Stretch updates
Morganizer
Re: L300 Stretch updates
Post by Morganizer »
Since you missed the group buy on the snorkel, have you talked to Butch at CVI? I was there about a month ago, and he had an L300 parts vehicle out front that had a snorkel.
Super Exceeded
Vehicle: 1993 L300S
Post by Super Exceeded »
Wow, now that that ugly part of my life is behind me, I can get started again. Installed the distributor this morning. Had to cur out the back of the firewall to get it there.
First I made the bottom cut, installed the hinges, then made the next three cuts. She slipped right in!
thedjjack
Vehicle: 1989 L300 HITOP!!
Post by thedjjack »
Just so you know the distributor is on the front of a Ford small block :-D :-D :-D :-D :-D :-D
So get the wires on and fire that pig up!!
Super Exceeded
Vehicle: 1993 L300S
thedjjack wrote:Just so you know the distributor is on the front of a Ford small block :-D :-D :-D :-D :-D :-D
Funny, you're not the first to say that!!
Just noticed the fuel pump has been compromised, but electrical should be done in the next few days..
Super Exceeded
Vehicle: 1993 L300S
Aux switch panel now fully wired.
Super Exceeded
Vehicle: 1993 L300S
Spent all day doing a 2 hour job because i keep forgetting to think ahead and had to undo everything at least twice. I was smart enough to take photos of everything, however I was not smart enough to put the card in the camera. So all I have is a finished photo.
First pic is the back side of the center console. The second are the wires for the light bar, The come out just below the drip rail behind the pax door. There are three layers of metal there to drill through and try to feed wires through. I still need to put a ground wire through and then seal with silicone. Exhaust headers were dry fitted today as well.
Super Exceeded
Vehicle: 1993 L300S
Final adjustments on the back door. It's tough to remove these suckers by yourself......
thedjjack
Post by thedjjack »
Enough wiring pictures.... lets see some 6 wheel tires on fire small block burn outs... lets see if you can tear that thing into 2 Delicas again... light them up... (already)
Super Exceeded
Vehicle: 1993 L300S
thedjjack wrote:Enough wiring pictures.... lets see some 6 wheel tires on fire small block burn outs... lets see if you can tear that thing into 2 Delicas again... light them up... (already)
ya ya New plugs, new starter, custom rad, and fuel pump all arrived, just waiting for the exhaust manifold bolts, they needed to be special ordered. Should be here tomorrow. Truck is being worked on outside right now and it;s just to damn cold..
Super Exceeded
Vehicle: 1993 L300S
Well the front end is out.
SAS next week (hopefully, parts are on order)
Super Exceeded
Vehicle: 1993 L300S
Well It's all cut away. (I Takes a few blades to cut out welding that you put in with the intent for it to stay) And the dry fit for the SAS is happening tonight.
Super Exceeded
Vehicle: 1993 L300S
Bit the bullet and hired in some guns = Leaf springs hung!!!
Hopefully over the next week I'll get the axle installed and then we can reattach the steering. Custom rad is supposed to finally arrive this week.
Super Exceeded
Vehicle: 1993 L300S
Front axle in and staying there, starter in, fuel pump in, timing done.
Getting closer
almac
Vehicle: '91 Delica "Tessen"
Post by almac »
i hope you plan on using some kind of 'sound deadener product' inside the delica, otherwise you may develop hearing damage. :o :?
al
thedjjack
Post by thedjjack »
that looks like it is going to be fun...
