My New 92 Delica Project
Pajero
Vehicle: 94 Pajero
Post by Pajero »
Well here it is! The start of my new project!
92 L300 Delica 209000kms
Work that needs to be done
-Engine needs to be replaced as its done...looking for new or used not sure yet wich way to go
-Need seats for the back as there are none.
-Back door panel is missing
-windshield needs to be replaced
-rear bumper corner damaged so i want to replace.
Thats it to start! :shock: :M
Re: My New 92 Delica Project
Great project - Have fun and keep us posted with your progress :)
I think '92 is possibly the best year. Looking forward to seeing your progress.
Pajero
Vehicle: 94 Pajero
Post by Pajero »
FalcoColumbarius wrote:I think '92 is possibly the best year. Looking forward to seeing your progress.
Thanks, i'll make sure to take pictures as I go. Hope to have it running by next fall for my winter ride....will be spending lots of time rust proofing everything.
Spent a few hours just cleaning the interior, looks way better now after a few buckets of black water......
I felt bad as it was given up by its previous owners to the GM dealer in town for its cash for clunkers sale........ :shock:
And apparently its Miss Lil' Bitchi's 1/2 sister?? but still trying to figure out the blood lines ... 8-) lol
Joe :M
thedjjack
Vehicle: 1989 L300 HITOP!!
Post by thedjjack »
1989 is the best year:
1) headlights that actually light the road
2) 24 years old so can be soon sold to USA for $$$$$
-I would do the new motor...and the used turbo, head, injector pump worth some $$$
back seats are typically free...hardest part is lifting it :-D
Pajero
Vehicle: 94 Pajero
Post by Pajero »
back seats are typically free...hardest part is lifting it :-D[/quote]
Would like to do a mild lift 2" or so after I get it running! lol.....The turbo I think is what may have killed the lower bearings as its covered in oil. Also the frame is covered in oil on that side....lost oil pressure.....just my guess so far..
I guess if the head/injection pump are still good it could help pay for the new motor...and help some peeps out on here....never though of that
BCDelica
Vehicle: WVO Powered Tuk Tuk
Post by BCDelica »
Pajero wrote:-I would do the new motor...and the used turbo, head, injector pump worth some $$$
Thanks[/quote]
Have you considered importing a second low grade, low mileage similar Delica yourself as a part vehicle?
I agree with thedjjack, the squares are the best.
Image Call me BCDelica-less
Pajero
Vehicle: 94 Pajero
Post by Pajero »
Ok so had a look at the headlights on this thing and im not sure if they got changed....(just looked up Koito on here and think I found my answer...)starting to wonder who inspected it...put it in my name at ICBC with no problems so I think it must have been inspected at some point....have to look for a decal havent seen that yet
And this was attached to the dash anyone know what it means? or says?
yojimbo
Post by yojimbo »
No Smoking.
1994 L300 Jasper
1986 Scimitar 1.8Ti
Pajero wrote:Ok so had a look at the headlights on this thing and im not sure if they got changed....(just looked up Koito on here and think I found my answer...)starting to wonder who inspected it...put it in my name at ICBC with no problems so I think it must have been inspected at some point....have to look for a decal havent seen that yet
Chances are with the Japan tag on the lenses I'd say they are not up to code. Is there a number in a circle? That will give you the "E" code which you can compare in this thread. Ultimately if you shine your headlamps against a wall and the flare goes to the left the lamps are designed for vehicles that drive on the left side of the road. If they flare to the right then they are designed for vehicles that drive on the right side of the road, like in Canada. If the flare goes to the left then you are blinding the oncoming traffic, much like driving with one's high beams on.
Rattlenbang
Vehicle: delica
Post by Rattlenbang »
Don't be surprised: my van had passed "inspection" and is licensed for the road, and non of the required changes had been made. You might want to go over the list and make sure the other stuff has been done, which I doubt as I don't see side reflectors.
thedjjack
Post by thedjjack »
some times they get approved lights put in for the inspection and switch back after..
You could be pulled off the road and sent for an inspection at anytime...
Pajero
Vehicle: 94 Pajero
Post by Pajero »
Yeah I will be changing the headlights before I put it on the road, I'm just acting like it just came off the boat and going to change all the fluids/hoses and inspect everything to make sure its good to go, As I don't know any of the history on this van, I did find a dried up mouse on the side of the air filter! lol.
Took out all the carpets and seat today and started cleaning the seats, and going to toss the carpet out after I use ot for a template for some new rubber flooring.
Joe
thedjjack
Post by thedjjack »
Since it is going to be a winter beater you could leave the stock headlights and instead put a pair of snowplow lights on the bush-bar to be legal (snow plow lights would have the advantage of letting you see at night a plus in PG) and save $$$$$
Rattlenbang
Vehicle: delica
I've heard this before, but where do you buy snow plow lights?
